Originally Posted by Whippet
I got the following message in the DS message window:
ERROR Unhandled exception: edu.wpi.first.wpilibj.tables.TableKeyNotDefinedException: Unkown Table Key: /SmartDashboard/Forward Time at [edu.wpi.first.wpilibj.networktables2.NetworkTableNode.getDouble(NetworkTableNode.java:51), edu.wpi.first.wpilibj.networktables.NetworkTable.getNumber(NetworkTable.java:294), edu.wpi.first.wpilibj.smartdashboard.SmartDashboard.getNumber(SmartDashboard.java:144), org.usfirst.frc.team4301.robot.Robot.disabled(Robot.java:90), edu.wpi.first.wpilibj.SampleRobot.startCompetition(SampleRobot.java:126), edu.wpi.first.wpilibj.RobotBase.main(RobotBase.java:234)]
What are we doing wrong?
This is telling you that your code is crashing on line 90 because the SmartDashboard value you are getting doesn't exist. You can either surround those gets by try/catch, or add a default value like you used other places.
