Go to Post Based on my experience coaching basketball and robotics, there is no doubt in my mind that if a sports coach receives $x then a robotics coach should, too. - dtengineering [more]
Unread 03-01-2015, 14:30
JohnM's Avatar
JohnM JohnM is offline
FRC #5854 (Glitch)
JohnM has a spectacular aura aboutJohnM has a spectacular aura about
WPILIB C++ Documentation
Does anybody know where the documentation is for the 2015 WPILIB C++? I cn only see the 2014 so far when doing Google searches. Although it will be really similar, there must be new documentation somewhere, right?
John
Unread 03-01-2015, 14:39
TeleTurbans TeleTurbans is offline
FTC #0116
TeleTurbans is an unknown quantity at this point
Re: WPILIB C++ Documentation
I think this might help. https://wpilib.screenstepslive.com/s...eclipse-c-java
Unread 03-01-2015, 15:19
nandeeka's Avatar
nandeeka nandeeka is offline
FRC #1868
nandeeka is on a distinguished road
It can be found at http://first.wpi.edu/FRC/roborio/release/docs/cpp/
Unread 11-01-2015, 10:13
MamaSpoldi's Avatar
MamaSpoldi MamaSpoldi is offline
Programming Mentor
AKA: Laura Spoldi
FRC #0230 (Gaelhawks)
MamaSpoldi has a brilliant futureMamaSpoldi has a brilliant futureMamaSpoldi has a brilliant futureMamaSpoldi has a brilliant futureMamaSpoldi has a brilliant futureMamaSpoldi has a brilliant futureMamaSpoldi has a brilliant futureMamaSpoldi has a brilliant futureMamaSpoldi has a brilliant futureMamaSpoldi has a brilliant futureMamaSpoldi has a brilliant future
Unhappy Re: WPILIB C++ Documentation
We are wondering about this as well. We had no trouble finding the online documentation but we used to get a local copy of the WPILib documentation (as well as a copy of the source code) when we installed the WPILib updates. Now the documentation only appears to be available online and we have not found a convenient way to grab a local copy... and we do not appear to have access to the source code at all (only header files). In addition we have just noticed that we cannot have the WiFi connect while connecting the the roboRIO over ethernet. This causes a conflict in being able to view documentation and program the roboRIO on a laptop. Hopefully they will fix this soon by making a soft copy of the Doxygen documentation available as a pdf or similar that can be hosted locally on a laptop.
Unread 11-01-2015, 16:30
mandrews281 mandrews281 is offline
FRC #0281
mandrews281 is a splendid one to beholdmandrews281 is a splendid one to beholdmandrews281 is a splendid one to beholdmandrews281 is a splendid one to beholdmandrews281 is a splendid one to beholdmandrews281 is a splendid one to beholdmandrews281 is a splendid one to behold
I remember reading a note somewhere in the online documentation saying they haven't created the 2015 Windows help file yet and they hoped to get it out in one of the updates.
Michael Andrews
Team #281 Programming Mentor
Unread 29-01-2015, 12:17
BenjaminWard BenjaminWard is offline
Programming/Controls
FRC #0612 (Chantilly Robotics)
BenjaminWard is an unknown quantity at this point
Is there an update on this? My team has a copy of the docs but the search functionality doesn't work correctly for whatever reason.
Unread 29-01-2015, 14:29
Jared's Avatar
Jared Jared is offline
We managed to get both working at the same time if we connect to the wi-fi network after we connect to the roboRIO. I don't think it matters, but the computer was plugged into the radio, not directly into the roboRIO.
Unread 29-01-2015, 16:00
MamaSpoldi's Avatar
Programming Mentor
AKA: Laura Spoldi
Sorry. I mis-spoke. I meant when connected to the roboRIO through the wireless (as opposed to the USB). But thanks for that update.
Unread 30-01-2015, 19:30
FRC #0281
I generated a copy and posted a zip file of the .chm file. Look for the second .zip file in this thread:
http://www.chiefdelphi.com/forums/sh...d.php?t=133453
Michael Andrews
