Go to Post Lets have fun this year - Wayne Doenges [more]
Unread 31-01-2015, 09:49
Re: SOLENOID
Lots of possibilities. Here is only one.
The solenoid needs to be Open'ed in Begin.vi and given a name there.
Unread 31-01-2015, 09:52
FrankenmuthK's Avatar
FrankenmuthK FrankenmuthK is offline
FRC #5215
FrankenmuthK is an unknown quantity at this point
Re: SOLENOID
What does the begin.Vi look like??
FRC 5215 <Steagles>
Unread 31-01-2015, 10:09
Re: SOLENOID
Here's another example showing the Open in Begin and it's use in Teleop.
Unread 31-01-2015, 10:43
FRC #5215
Re: SOLENOID
We are having trouble connecting the Select function to the Solenoid set. VI
Unread 31-01-2015, 10:46
Re: SOLENOID
Try these steps:
  1. Right-click on the input of the Solenoid Set and Create->Constant
  2. Copy/Paste the constant and attach two of them to the Select as shown
  3. Delete the constant attached directly to the Solenoid Set
  4. Wire the Select to the solenoid Set
That makes sure the enumerated constants used are the correct ones for Solenoid Set.
Unread 31-01-2015, 10:52
FRC #5215
Re: SOLENOID
Try these steps:
Thank you so much for your help!!! sorry for all of the questions, but could you show us the finish.VI?
THank you so much again
Unread 31-01-2015, 11:02
Re: SOLENOID
Finish isn't technically necessary, it's just good form.
Unread 31-01-2015, 12:18
ale_jero ale_jero is offline
FRC #5215
ale_jero is an unknown quantity at this point
Re: SOLENOID
Lastly, how do we program the compressor?
Unread 31-01-2015, 12:24
Re: SOLENOID
By creating a solenoid, the compressor was automatically created too.
No explicit code is required for the compressor.
All this does assume that your PCM has a CAN ID of 0
