Go to Post Maybe you should whack it a few times with a hammer. That always seems to fix our robots. - Adam Y. [more]
Unread 29-01-2015, 17:39
hyprvx's Avatar
hyprvx hyprvx is offline
AKA: Devon
FRC #2151 (Monty Pythons)
hyprvx is an unknown quantity at this point
Relays only going backwards?
So we have one relay set on relay output 0, configured in both directions. We have boolean variables true if button 5 or 6 is held, respectively, and two while loops if those variables are true. In those loops, we have the relays set to trigger forwards or backwards, and when the code breaks out of those two loops, set back to off. The loop for backwards works perfectly; when I hold button 5, the relay triggers to go backwards. But button 6, when held, does nothing. We have stepped through the code with the debugger, and it's supposed to be setting the relay to forwards, but it does nothing. Help?
Our code is at https://github.com/caffeinatedDrummer/2151-Code
My userbars were eaten by Cthulhu.
FRC team 2151, the Monty Pythons!
Unread 30-01-2015, 10:39
notmattlythgoe's Avatar
Flywheel Police
AKA: Matthew Lythgoe
FRC #2363 (Triple Helix)
Re: Relays only going backwards?
When you step through the code with the debugger does it attempt to execute the line that sets the relay to forward?
Unread 30-01-2015, 11:06
mmaunu's Avatar
mmaunu mmaunu is offline
FRC #2485 (W.A.R. Lords)
mmaunu is a jewel in the roughmmaunu is a jewel in the roughmmaunu is a jewel in the roughmmaunu is a jewel in the rough
Everything looks fine in the code, but...
Have you verified that you are correctly detecting button 6? The debugger shows that you are in the correct loop when button 6 is held down?
Can you tell us what the relay is controlling and show a picture of the wiring?
2014 Las Vegas (Winners with 987, 2478; Excellence in Engineering)
2014 San Diego (Finalists with 987, 3250; Quality Award)
2013 Inland Empire (Winners with 1538, 968; Excellence in Engineering Award)
2013 San Diego (Finalists with 2984, 4322; Creativity Award)
2012 Las Vegas (Finalists with 2034, 3187; Quality Award)
Unread 30-01-2015, 20:50
Does the LED on the relay change when you command the relay in reverse?
Unread 31-01-2015, 10:04
hyprvx's Avatar
AKA: Devon
Yes, we see it's executing relayArms.set(Relay.Value.kForward); but no light change occurs.
We are detecting button 6, and the second part just answered above.
Yes, the relay LED changes to indicate reverse, and outputs the -12v, but does nothing on forward.
The relay is to control the motor for part of our arms mechanism.
This is a photo of our electronics board. The spike I am pointing to is the one we wish to control. The spike on the right does not work properly and will be removed soon.
Unread 31-01-2015, 11:51
hyprvx's Avatar
AKA: Devon
I would like to update to say we have solved the problem. Our connections to the RoboRIO from the Spike were in backwards, enabling us to go backwards, but not forwards. Correcting the PWM connection to the RoboRIO has fixed the problem. I haven't yet seen any replies, so if anyone has suggested such a fix, thank you for noticing the problem before we did.
