Go to Post And when the President of the United States is playing with LEGOs and getting down on the floor to look inside of robots, then I would have to say "Mission Accomplished". - OZ_341 [more]
Unread 31-01-2015, 12:35
RoboBucs RoboBucs is offline
FRC #5005
RoboBucs is an unknown quantity at this point
Re: Adding a sensor reading to the dashboard
Originally Posted by adciv View Post
Use SD Write Value to send the value to the dashboard. It will show up under the Variables tab without having to change it. If you want it displayed, create an indicator with the same name as you gave the SD Write Value.
Awesome! Thank you both very much!
