Go to Post It's what this is all about. Making dreams happen. - Astronouth7303 [more]
Unread 31-01-2015, 13:01
RoboBucs RoboBucs is offline
FRC #5005
RoboBucs is an unknown quantity at this point
Re: Adding a sensor reading to the dashboard
Originally Posted by Mark McLeod View Post
No wiring is actually required.
Just the name has to exactly match.
You can see "My Number" on the bottom right of the Dashboard block diagram and that's all that is needed.
If you want to, you can explicitly read the value (just the opposite of the Write) and wire the read to the indicator.
But in the dashboard, whenever I create an indicator in the custom tab, it makes it in the VI's of the custom dashboard and gives me an error unless I wire it to a control, or am I just doing this completely wrong?
