Thread Tools |
Rating:
Display Modes |
Re: RoboRIO Red Power LED
And for those who are curious, the returned units end up on my desk where we take them apart to see what is going on.
I may have a solution to your problem. We had the same issue with the solid red power light. We went through and unplugged all the fuses except the ones to the vrm. That wasnt the problem. So we went one by one on the PWM's and discovered that on one of them, some knucklehead switched the red and black wires on it so that the negative was in the middle instead of the positive. I unplugged it and swapped the wires back to normal and it worked.
Hope this helps. |
The controller has conformal coating so things that can be permanently damaged are protected from swarf (or random wires), but IO pins are exposed and while no lasting damage occurs, there can be a short condition that requires a little cleaning to clear up.... or a violent hit, especially if your robot's name is "tippy". |
We're not "tippy", but it is possible that something lodged under one of the IO pins that we couldn't find. If you come across one that's set for team 4499, that's the one we messed up.
#7
On Friday I performed an IR scan on this unit and found the over current protection engaged (expected for a 5V short) but no other hot spots. Compressed air under the AI/Relay IO connectors seemed to have cleared the fault. I suspect that the air dislodged whatever was causing the short condition though I never did see what was shorting it.
#8
Dean |
#9
Quick side note: make sure the fuses on your RoboRIO are in all the way and properly secured. Our fuse kept on getting knocked out of place, causing the RoboRIO to reboot during matches.
