Go to Post Pneumatic components always give me gas... - Alan Anderson [more]
Unread 31-01-2015, 06:55
nixiebunny nixiebunny is offline
AKA: David Forbes
FRC #4183 (Bit Buckets)
nixiebunny has a reputation beyond reputenixiebunny has a reputation beyond reputenixiebunny has a reputation beyond reputenixiebunny has a reputation beyond reputenixiebunny has a reputation beyond reputenixiebunny has a reputation beyond reputenixiebunny has a reputation beyond reputenixiebunny has a reputation beyond reputenixiebunny has a reputation beyond reputenixiebunny has a reputation beyond reputenixiebunny has a reputation beyond repute
pic: TALEN-A Talon SRX breakout board top view
Unread 31-01-2015, 06:57
Foster Foster is offline
Engineering Program Management
VRC #8081 (STEMRobotics)
Foster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond repute
Re: pic: TALEN-A Talon SRX breakout board top view
Very nice. Why did you go with male pins on the board? I always worry about swarf shorting the pins out.
Do you put this on all your SRX devices so they are all the same?
Foster - VEX Delaware - 17 teams -- Chief Roboteer STEMRobotics.org
2010 - Mentor of the Year - VEX Clean Sweep World Championship
2006-2016, a decade of doing VEX, time really flies while having fun
Downingtown Area Robotics Web site and VEXMen Team Site come see what we can do for you.
Unread 31-01-2015, 09:09
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
FRC #1726 (N.E.R.D.S.)
That's the problem with building a plywood robot... you don't think about swarf shorting things.
Unread 31-01-2015, 09:27
AKA: David Forbes
I chose the same male PWM connectors that are on the roboRIO, because they are the standard connectors that every team already has dozens of cables to fit. The encoder connectors take the same plug on both ends of the cable, so you only have to buy one type of plug for the cables.
The board can be populated with any 0.1" pitch connectors you like.
--David Forbes
Mentor, Bit Buckets team 4183. Assistant cat herder and dispenser of legendary tales.
Need a Nixie watch? Yes, you do. Ask me.
Unread 31-01-2015, 13:48
Good point, but here on the East Coast we call plywood swarf "saw dust" but I saw what you did there....
Makes good sense, thanks for the thought process behind the design.
