Go to Post Now, FIRST has taken over my life (and my harddrive)! - Kate00 [more]
Unread 31-01-2015, 13:49
Zephex Zephex is offline
FRC #2213
Zephex is an unknown quantity at this point
Issues with multi-tasking
Alright, so as you guys can see in the pictures above I'm reading the values from X2 and Y2 and putting them into the motor, and I'm also using a gyro in order to stabilize the robot. Problem is, since I can't use a delay function, I'm forced to use a wave function. What I first wanted to ask is if there's a way to not use the wave function and somehow use the delay one without it stopping my enitre loop since I always have to check the values of the gyro. The second question is(if I must use the wave function) why when I'm putting 2 seconds in the frequency(Time2 box), its not actually doing the action for 2 seconds? basically what I'm trying to multitask, since I need to always check the gyro values.
Thanks in advance guys!
Unread 31-01-2015, 14:31
plnyyanks's Avatar
Data wins arguments.
AKA: Phil Lopreiato
Re: Issues with multi-tasking
What's the reason for using a wave function?
If I understand your goals correctly, a better approach will be to, on a button press say, store the current time + your delay in a shift register, and compare the stored value to the current time every iteration. Then, you can put your deferred action into a case structure and process it there.
Unread 31-01-2015, 15:44
"Multitasking", or parallel execution of independent tasks, is something that LabVIEW does without effort. However, I want to understand what you want the code to do before I give advice that might not be appropriate. Is this supposed to be part of your Autonomous?
Unread 01-02-2015, 09:55
Can you tell where this code is located? If it is teleOp, I suspect you do not need a loop at all.
So a better description of where the code runs or what it is meant for will help.
Greg McKaskle
