Go to Post remember kids, never listen to Big Mike.... - Mike Schroeder [more]
Thread Tools Rating: Thread Rating: 8 votes, 5.00 average. Display Modes
Unread 31-01-2015, 13:07
kinganu123 kinganu123 is offline
FRC #1747
kinganu123 is on a distinguished road
Syncing CANJaguars with PID?
So we have 3 motors (and therefore 3 CANJaguars) hooked up to drive our elevator. Since only one encoder is needed on the output shaft, only one of the jags has the encoder hooked up to it. My question is, is it possible to use the internal position PID that the CANJaguars use and sync it up with the other 2 Jaguars, or should we just go with one external PIDController?
Also, we feel that getting the speed of the pid-enabled jag and setting it to the same as the other two will have some downsides to it, so we want to avoid that option.
Unread 31-01-2015, 14:32
Re: Syncing CANJaguars with PID?
You should run the PID in the roboRIO or use Talon-SRXs. Trying to use the Jaguar PID with three Jags will cause you nothing but headaches.
Unread 31-01-2015, 14:57
Agreed.
But I'm curious: Has anyone ever tried reading the voltage on the leads of the motor attached to the master Jag (the one with the encoder) and using that voltage to send commands to the other two Jags (set to voltage mode)? Did it work?
Name:	CAN Jag sync.png
Unread 31-01-2015, 16:25
FRC #1747
Yeah, we may test it, just for kicks.
Unread 31-01-2015, 17:32
You might want to post your custom circuit here for comment before doing so.
Unread 04-02-2015, 13:04
cstelter cstelter is offline
Programming Mentor
AKA: Craig Stelter
FRC #3018 (Nordic Storm)
cstelter will become famous soon enough
Our experience with using CAN Jags and java programming (from 3 years ago) was that there was an extraordinary delay associated with CAN traffic. see http://www.nordicstorm.org/Resources...2/Default.aspx for details.
We coded the same test in C++ and saw nearly no delay associated with CAN.
So I think the latencey of the CAN/read + slave Jag reaction would make or break this thought of reading the output voltage on one Jag and transferring it. Things may be very easily done with our faster RIO.
