Go to Post Woody, If there is any chance your reading this ... you've changed my life. - Gope [more]
Unread 31-01-2015, 14:42
Bmarshall645 Bmarshall645 is offline
AKA: Brendan Marshall
FRC #4905 (Andromeda One)
Team Role: Webmaster
Bmarshall645 is a glorious beacon of lightBmarshall645 is a glorious beacon of lightBmarshall645 is a glorious beacon of lightBmarshall645 is a glorious beacon of lightBmarshall645 is a glorious beacon of lightBmarshall645 is a glorious beacon of light
robot base
Can we mount the electronics on to a steel plate on the robot?
Battlecry@WPI 17 (Field Reset, Team Social), NE Boston District Event 2016 (Field Reset)
Unread 31-01-2015, 14:49
DaRealSlimShady's Avatar
DaRealSlimShady DaRealSlimShady is offline
Young $$$
Rookie Year: 1972
DaRealSlimShady is infamous around these partsDaRealSlimShady is infamous around these partsDaRealSlimShady is infamous around these parts
Re: robot base
I give you my permission, but it would be better to check the rules.
Unread 31-01-2015, 15:18
MrBasse MrBasse is offline
FRC #3572 (Wavelength)
MrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond repute
Re: robot base
There is nothing that says you can't. That being said, we use plastic to avoid the possibility of shorts and other electrical issues. The new control system isn't as touchy as the old one was, but make sure you electrical is clean and has no exposed wiring near metal.
We've lost a few expensive components over the years by having PWM cables short or by having insulation wear on other wiring that has caused issues. A little bit of planning can avoid all of that.
Andrew Basse
Coach - FRC Team 3572 - Wavelength
Unread 31-01-2015, 15:23
Captain_Kirch Captain_Kirch is offline
Alumni
AKA: Aaron Kirch
FRC #1625 (Winnovation)
Captain_Kirch is a jewel in the roughCaptain_Kirch is a jewel in the roughCaptain_Kirch is a jewel in the roughCaptain_Kirch is a jewel in the rough
Re: robot base
Mounting electronics on metal is generally a bad idea for 2 reasons.
1. It conducts electricity!
2. It's heavy. Especially if you're talking about using steel. Electrical components aren't terribly heavy, steel would be overkill.
Ideally electronics should be mounted on something light, non conductive, and easily accessed yet not exposed.
Unread 31-01-2015, 15:33
Mike Marandola Mike Marandola is offline
Lead Bumper Mentor
AKA: Mike Marandola
FRC #0316 (Lunatecs)
Mike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond repute
Re: robot base
Unless you need the weight for ballast and the bellypan would be a pretty good spot to add it.
2015 - Pioneer Valley District Finalists/Upper Darby District Finalists/MAR District Championship #1 Seed and Winners with 225 and 203
2014 - Lenape Seneca District Winners/Chestnut Hill District Winners
2013 - Lenape Seneca District Winners/Chestnut Hill District Finalists
2011 - Philadelphia Regional Finalists
2009 - Finger Lakes Regional Finalists
Unread 01-02-2015, 03:04
GeeTwo's Avatar
GeeTwo GeeTwo is offline
Technical Director
AKA: Gus Michel II
FRC #3946 (Tiger Robotics)
Re: robot base
Sure, but just because you can doesn't mean you should. Why in the world would you want to mount to a heavy plate that increases your risk of violating R27?
All wiring and electrical devices, including all Control System COMPONENTS, shall be electrically isolated from the ROBOT
frame. The ROBOT frame must not be used to carry electrical current
Unread 01-02-2015, 11:52
cgmv123's Avatar
cgmv123 cgmv123 is offline
FRC RI/FLL Field Manager
AKA: Max Vrany
FRC #1306 (BadgerBOTS)
Re: robot base
None of the 2015- control system components have grounded frames or other metal elements. (Unless you still have an Axis 206 camera.)
That said, I agree that steel is too heavy for an electrical board. I personally recommend 1/4" polycarbonate. It's light for its size, thick enough so it doesn't flex, and strong enough to add a degree of rigidity to your frame when mounted properly. (And clear so it can give your robot a cool factor!)
Unread 01-02-2015, 12:14
MrForbes's Avatar
AKA: Jim
FRC #1726 (N.E.R.D.S.)
Re: robot base
26 gauge sheet steel (available at most building supply stores) weighs about half as much as 1/4" polycarbonate per unit area, and weighs just a tad more than 0.1" thick polycarbonate (this thinner polycarbonate is also available at most building supply stores).
We prefer plywood, it's inexpensive, relatively light, rigid, insulating, and easy to work with. And you can screw wood screws into it.
And there isn't really much need to save weight on the bottom of a tall robot--one trick is to make the bottom as heavy as you want, which forces you to make the top of the robot lighter, and thus you have a more stable robot. Robots tipping over might be an issue this year, even without defense being played.
Unread 01-02-2015, 15:24
PAR_WIG1350's Avatar
AKA: Alan Wells
FRC #1350 (Rambots)
Re: robot base
Mounting your Talon SRX and Victor SP motor controllers to metal might actually be desirable for heat dissipation, but it isn't necessary.
Unread 02-02-2015, 08:07
GeeTwo's Avatar
Technical Director
AKA: Gus Michel II
Re: robot base
Many teams (including ours) have a few custom circuits on the control board (gyroscope, sensor breakouts, relay module for LEDs) which must be insulated.
If you're still using Talon SRs or other relay modules with screw terminals, or if the power plug falls out of the wireless module, a non-conducting board limits the effect of a wire that comes loose.
Unread 02-02-2015, 09:16
evanperryg's Avatar
evanperryg evanperryg is offline
IT'S THE BUMP N' DUMP
AKA: Evan Grove
FRC #4536 (The Minutebots)
evanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond repute
Re: robot base
In 2014, my team mounted the electrical system on a lexan bellypan. Put simply, it was a mild disaster. Although it is "safer" to put electronics on (insulates, less weight, etc.) A piece of lexan with a bunch of heavy parts on it, mounted an inch off the ground, does not go very well after a season of wear and tear. This year, we are using perforated aluminum for the bellypan, and lexan for a secondary board. Why not aluminum for this one too? Aluminum's heavier and would raise the robot CoG.
So:
Lexan is the way to go for boards that are high off the ground, when heatsinking and durability are not a major concern.
Aluminum is the way to go for low-mounting boards, when heatsinking and durability are important.
FRCDesigns Contributor | "There is only one corner of the universe you can be certain of improving, and that's your own self." -Aldous Huxley
2012-2016 | FRC Team 2338: Gear it Forward
2013
Wisconsin Regional Winner 2014 Midwest Regional Finalist 2015 Midwest Regional Chairman's Award, Finalist, Archimedes Division Champion, IRI Semifinalist 2016 Midwest Regional Chairman's Award, Finalist, Archimedes Division Gracious Professionalism Award, R2OC Winner
2015 | FTC Team 10266: Mach Speed
2015
Highland Park Qualifier Winner, Motivate Award
2017-???? | FRC Team 4536: The Minutebots
Thanks to the alliances and friends I've made along the way: 33 74 107 111 167 171 234 548 1023 1089 1323 1625 1675 1732 1756 2064 2077 2122 2202 2358 2451 2512 2826 3936 3996 4039 4085 4241 5006 5401 5568 5847 5934
Unread 02-02-2015, 09:31
Re: robot base
Another issue with very low mounted lexan and electronics is the possibility of static buildup/discharge as it brushes over the carpet.
Unread 02-02-2015, 12:20
Re: robot base
Just about anything can be used to mount control system components. We have used perforated aluminum from McMaster for many years. It is lightweight, we use tywraps to hold everything in place (including wiring), and you can see through it. I have a few suggestions though for anyone designing their system now.
1. Please don't mount everything upside down on the bottom of your robot. Items will get damaged when you roll over debris on the field and gravity will work against you when something (breakers!) loosens. (If you are thinking there is nothing to run over, I can assure you, there will be!)
2. All system components need to be visible to both Inspectors and field people who are trying to help you run on the field. If we can't see, we may not be able to help. That means your robot might sit doing nothing in a match or two.
3. If you are going to use metal and intend on drilling mounting holes, be sure to clear away all conductive debris (SWARF) with a vacuum (not compressed air) to insure nothing enters electronics like the RoboRio and PDP and motor controllers.
4. We use tywraps (wire ties in your area) because you only need one tool to remove and replace anything on the board. We never have a conductive item (like a lock washer or nut) fall where we can't get at it or worry where it went when we can't find it.
