Go to Post Aaaaah! I think my head just exploded from looking at this awesomeness. You guys are great. This is super cool. :) - Ian Curtis [more]
Unread 31-01-2015, 14:50
Potatoes's Avatar
Potatoes Potatoes is offline
AKA: Eric Wittmann
FRC #5136 (Mecha Pirates)
Potatoes is an unknown quantity at this point
20 AMP power to motor controllers?
We have run out of 40AMP slots on our power distribution board, we were wondering if it's possible to attach our other 2 motors to the 20AMP slots. The motor controllers are Victor 888's. Is there any restriction on the size of the motor that can be connected?
Unread 31-01-2015, 15:03
GavinoSkaar GavinoSkaar is offline
FRC #3219 (TREAD)
Team Role: Electrical
GavinoSkaar is an unknown quantity at this point
Re: 20 AMP power to motor controllers?
You can hook up motor controllers to the PD board according to the game manual, but you cannot hook up the motor controllers to CIM motors. It's under the 4.8: Power Distribution Section in the manual.
Unread 31-01-2015, 15:08
orangemoore orangemoore is offline
AKA: Roger Moore
FRC #3135 (Robotic Colonels)
orangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond repute
Why?
Point exactly to what rule says that.
Stronghold
Student 2013-2016
3135 -- Robotic Colonels
3507 -- Robotheosis (FTC)
Unread 31-01-2015, 15:12
FRC #3219 (TREAD)
Tables 4-2 and 4-4 show what can be hooked up to the right terminal. And I think CIM motors just need more amperage to operate.
Unread 31-01-2015, 15:16
AKA: Roger Moore
I don't think that is what that means.
Table 4-2: Branch Circuit Protection
Branch Circuit Circuit Breaker Value Quantity Allowed Per Breaker
Motor Controller Up to 40A 1
It can be run on any breaker up to 40A it does not have to though.
Stronghold
Student 2013-2016
Unread 31-01-2015, 15:19
FRC #3219 (TREAD)
It's very possible I'm wrong.
Unread 31-01-2015, 17:36
Fletch1373's Avatar
Fletch1373 Fletch1373 is offline
AKA: Fletch
FRC #3181 (Panthers)
Fletch1373 has much to be proud ofFletch1373 has much to be proud ofFletch1373 has much to be proud ofFletch1373 has much to be proud ofFletch1373 has much to be proud ofFletch1373 has much to be proud ofFletch1373 has much to be proud ofFletch1373 has much to be proud ofFletch1373 has much to be proud ofFletch1373 has much to be proud of
I've been unable to find a rule this year that specifies what motors are allowed to be connected through what breakers, but historically CIMs have required 40A breakers. This is due to it having a much higher stall current(in the 60A range if memory serves).
If you do decide to put a CIM on a 20A breaker, just remember that the breaker is there to protect the wire, but there's still a chance of the high current burning out the wire before the breaker trips if the motor stalls. The AWG requirement in table 4-3 is just a minimum, so feel free to go higher in this case.
Student:
<04: FRC0213> <05-08: FRC1373>
Mentor:
<09-10: FRC0809> <11-12: FRC3555> <12-14: FRC0073> <15-??: FRC3181>
Volunteer:
<FTAA> <CSA> <Defense Coordinator> <Scorekeeper> <Robot Inspector> <Official Scorer>
2016 Tour:
CTWAT [DefCoord] > Pittsburgh[Mentor/DefCoord] > TVR[FTAA] > FLR[CSA] > NE DCMP[CSA] > CMP[CSA]
Unread 31-01-2015, 17:47
Chris_Ely's Avatar
Chris_Ely Chris_Ely is online now
AKA: luckof13
FRC #3414 (HackBots)
Chris_Ely has a reputation beyond reputeChris_Ely has a reputation beyond reputeChris_Ely has a reputation beyond reputeChris_Ely has a reputation beyond reputeChris_Ely has a reputation beyond reputeChris_Ely has a reputation beyond reputeChris_Ely has a reputation beyond reputeChris_Ely has a reputation beyond reputeChris_Ely has a reputation beyond reputeChris_Ely has a reputation beyond reputeChris_Ely has a reputation beyond repute
As far as I know, there hasn't been a rule limiting certain motors to breaker sizes. The rules dictate the minimum wire gage that can be connected to a certain size breaker.
The CIM's stall current is 133A at 12V.
2013: Waterford Finalist, Livonia Winner, MSC Quarterfinalist, Curie Division
2012: Waterford, Northville, Livonia
2011: Waterford Finalist, Livonia
2010: Ann Arbor Rookie Inspiration Award, Troy
Mechanical Engineering Student,
Michigan Technological University
Unread 31-01-2015, 19:25
PAR_WIG1350's Avatar
AKA: Alan Wells
FRC #1350 (Rambots)
The limiting factor regarding what motors can use what breakers is purely the fact that some combinations will not work well. As long as your wire gauge matches the breaker size, safety will not be an issue, as such, they appear to have decided not to create a rule that explicitly lists allowed or disallowed motor and breaker combinations.
My advice is to find the motor documentation and prioritize which motors get the 40 amp circuits based on that.
Unread 01-02-2015, 00:36
GeeTwo's Avatar
GeeTwo GeeTwo is offline
Technical Director
AKA: Gus Michel II
FRC #3946 (Tiger Robotics)
I agree that there are no rules forbidding connecting a CIM to a motor controller on a 20A breaker. However, unless you just happen to have a stack of CIMs in your inventory and no smaller motors, this is rather like getting a truck with a V8 engine then feeding it with a tiny fuel line. You'd be better off using a mini-CIM or other mid-size "unlimited" motor which will perform better at 20A.
Unread 01-02-2015, 03:47
asid61's Avatar
asid61 asid61 is offline
AKA: Anand Rajamani
FRC #1072 (MVRT)
+1. The extra power of the cim will be deadweight on a 20 amp breaker.
I would be concerned about running down the battery if I was using up every single 40 amp slot and still needed more cims.
Unread 01-02-2015, 04:46
Fletch1373's Avatar
AKA: Fletch
Thanks for the correction on stall current. I was honestly just guessing on the number because I couldn't easily look it up, but I knew it was well above 40A.
Anyway, I've been an inspector multiple times over the last 7 years I've been volunteering and have had to tell teams to change where CIM motors could be wires. This means it was on the inspection checklist, which means there was a rule for it. You may be true that there was no explicit list of what motors could be connected to what breakers, but there has been a rule in the past that said what breaker a CIM had to be on. I just woke up, so I'll update this comment as soon as I'm coherent enough to go find a source.
Student:
Mentor:
Volunteer:
2016 Tour:
Unread 01-02-2015, 09:20
TFleig78's Avatar
TFleig78 TFleig78 is offline
AKA: Tyler
FRC #0078 (Air Strike)
TFleig78 will become famous soon enoughTFleig78 will become famous soon enough
The smaller slots on the PDP can use 30A breakers
Unread 01-02-2015, 09:50
Dale27 Dale27 is offline
FRC #0027
Dale27 is an unknown quantity at this point
The SIMS come with a 14 gauge wire pigtail. Based on the wiring gauge table, does that limit it to a 30 amp breaker?
Unread 01-02-2015, 10:18
TFleig78's Avatar
AKA: Tyler
There is an exception to R38 that states : "Wires that are recommended by the device manufacturer or originally attached to legal devices are considered part of the device and by default legal. Such wires are exempt from R38."
So the way I read the rule, a cim may be used in a 40A breaker, assuming all of the wire leading to the motor is 12AWG, not including the stock pigtails.
