Go to Post Thanks for giving up your holiday for Science! - Foster [more]
Unread 31-01-2015, 14:50
jalozinski jalozinski is offline
FRC #4787
jalozinski is an unknown quantity at this point
USB Camera on Dashboard "Huffman Table 0x00 was not defined"
Our team is trying to get our USB Camera running on SmartDashboard, but whenever we try we get "Huffman Table 0x00 was not defined."
When we use the default dashboard, we're able to use the camera. But we want to make our own dashboard with this feature. Has anyone found a solution to this problem? Even when running the sample Simple Vision code we get the same error.
Unread 31-01-2015, 14:54
Re: USB Camera on Dashboard "Huffman Table 0x00 was not defined"
What camera? Is it the Lifecam-3000?
Unread 31-01-2015, 15:38
FRC #4787
Yep, the Life-Cam 3000. I take it that's part of the problem.
Unread 31-01-2015, 16:01
Tyfighter98's Avatar
Tyfighter98 Tyfighter98 is offline
Software Lead
FRC #3255 (Super NURDs)
Tyfighter98 is an unknown quantity at this point
My team uses the Lifecam-3000, and had this problem. It works on a 32bit operating system but not on 64bit. I am currently trying to replicate my results on a 64bit computer.
Unread 31-01-2015, 16:02
Software Lead
Also, the beta testers of the new control system were explicently told to use the tools in 32bit mode/environment. I think it is just a lack of comunication from FIRST.
Unread 31-01-2015, 16:19
FRC #4787
Actually, we're using 32bit Win7 (although it has 3GB of ram)
Still doesn't work. Weird right? I guess as a team we can't solve this without FIRST resolving it themselves.
Unread 31-01-2015, 16:21
dougwilliams's Avatar
dougwilliams dougwilliams is offline
Engineer - Controls, Electronics
FRC #2053 (TigerTronics)
dougwilliams is on a distinguished road
Is it a 32 bit OS or 32 bit tools? We uninstalled Java and Eclipse 64 bit versions and re-installed 32 bit versions and still had the same results. Would love to see a real solution to this problem.
Unread 31-01-2015, 16:31
Software Lead
It is my understanding that it is 32bit tools. I am working on getting it to work right now on a 64bit system. I will let you know if I get any results but from what I can tell, results are very inconsistent.
Unread 31-01-2015, 16:33
If you have any luck, please post. We tried 32 bit tools, and that still didn't work for us. If there's some remnant setting after re-installing that's possible - but a huge pain.
Unread 31-01-2015, 20:18
Software Lead
After a painstakingly long process, even running all the tools in 32bit mode is useless in getting USB webcams to work.
Unread 31-01-2015, 23:50
Tom Line's Avatar
Tom Line Tom Line is offline
Raptors can't turn doorknobs.
FRC #1718 (The Fighting Pi)
Can you be more specific? We were never told to use 32 bit software for anything.
Unread 01-02-2015, 02:31
Software Lead
My team was never a beta tester, it was what I read on another thread. I'm sorry, I can't really elaborate on that.
Unread 01-02-2015, 11:55
codedr codedr is offline
FRC #0537
codedr will become famous soon enoughcodedr will become famous soon enough
See the analysis of 'Missing Huffman table' in this post
http://www.chiefdelphi.com/forums/sh....php?p=1436598
Unread 06-02-2015, 22:35
Software Lead
After many hours of trial and error we managed to get the USB camera to work while running the Smart Dashboard (Java). All you need to do is create a new project example for Intermediate Vision and delete lines 39, 44, & 45 (just draws a circle on the viewer of the camera). You will have some unused imports so removed those and then just make sure you have created the object in Smart Dashboard and you will be set.
