Thread Tools |
Rating:
Display Modes |
Re: CAN Firmware Update Mandatory?
I can't say for sure, because other programmers were the ones who upgraded the firmware. How would I be able to check?
Use a web browser and go to roboRIO-3160.local
You'll see PCM on the left, click on it and the CAN ID will be at the top of the resulting page. |
I tried going to this address but only ended up doing a google search and not getting me anywhere.
Edit: I realized I should probably have my roboRIO on. I turned it on and made it to the page. Yes, the CAN ID is 0. Last edited by wildaburk3160 : 31-01-2015 at 17:31. |
You can also verify firmware versions on the diagnostics tab of the driver station.
Do you have code that starts a compressor? In Java, you would construct a Compressor object in some initialization code and then call start() on that object in your autonomous or teleop code.
That's not needed in 2015. Just construct a solenoid on the PCM and you should be all set code wise.
#7
There is a separate Compressor class that can be used if there are no Solenoid objects created in code.
