Go to Post Wisdom shared is priceless, isn't it? And timeless. - JaneYoung [more]
Unread 31-01-2015, 12:16
curtis0gj curtis0gj is offline
FRC #5033 (Beavertronics)
Rookie Year: 2015
curtis0gj will become famous soon enough
Xbox Axis Help
Howdy folks, I need some help with my Xbox 360 remote. Currently I am using the Buttons to send signals to victor motor controllers and spike relays, but I would like to switch over to the left axis for my victors and right axis for my relays. Here is my current code. Any help would be greatly appreciated.
    boolean buttonPressedForwardSpike = false; // these are in init.
    boolean buttonPressedForwardVictor = false; // init
            if (xbox.getRawButton(3)) {  // tele
            	spike1.set(Relay.Value.kForward);
            	spike2.set(Relay.Value.kForward);
            	buttonPressedForwardSpike = true;
            } else if (buttonPressedForwardSpike = true) {
            	spike1.set(Relay.Value.kOff);
            	spike2.set(Relay.Value.kOff);
            if (xbox.getRawButton(2)) {
            	spike1.set(Relay.Value.kReverse);
            	spike2.set(Relay.Value.kReverse);
            if (xbox.getRawButton(1)) {
            	victor1.set(.50);
            	victor2.set(.50);
            	buttonPressedForwardVictor = true;
            } else if (buttonPressedForwardVictor = true) {
            	victor1.set(0);
            	victor2.set(0);
            if (xbox.getRawButton(4)) {
            	victor1.set(-.50);
            	victor2.set(-.50);
Unread 31-01-2015, 13:10
kinganu123 kinganu123 is offline
FRC #1747
kinganu123 is on a distinguished road
Re: Xbox Axis Help
Use the driver station to find the raw axis values of the individuals joysticks (it's on one of the tabs on the bottom left hand side). Then, just call getRawAxis() on that axis you find.
Also, I'm sure if you look around on chiefdelphi, you'll find that people have already posted up their xbox class.
Unread 31-01-2015, 16:51
Rookie Year: 2015
Re: Xbox Axis Help
Could I use this picture http://team358.org/files/programming...rolMapping.jpg for the values or do I need to check the actual readings?
            if (xbox.getRawAxis(5)) {  // 5 being the Y axis on right stick
Unread 31-01-2015, 17:06
FRC #1747
Re: Xbox Axis Help
            // !!The below statement doesn't evaluate to a boolean
            // !!!!!!!!!!! The below staetment assigns instead of comparing
If that's the exact one, then yeah, it SHOULD be fine. Though I'd still recommend checking it, for sanity reasons.
Unread 31-01-2015, 17:37
Re: Xbox Axis Help
Check them. That picture looks like the old 2014 and earlier mapping.
Unread 31-01-2015, 19:22
Rookie Year: 2015
Re: Xbox Axis Help
Yeah it was, I found 2015 http://team358.org/files/programming...rolMapping.jpg
Unread 31-01-2015, 20:44
Rookie Year: 2015
Re: Xbox Axis Help
I may need some further assistance the getRawAxis is giving me an error saying that it cannot covert from double to boolean.
boolean buttonPressedForwardSpike = false; // init
Unread 31-01-2015, 21:18
Re: Xbox Axis Help
You will need to explain more about what you want the code to do. A joystick axis in WPILib returns a floating point value (double datatype) from -1.0 to 1.0. An if statement requires a boolean, true or false.
Unread 01-02-2015, 10:19
FRC #1747
Re: Xbox Axis Help
Check my second post.I've already put comments in there as to what you should change
