Go to Post The mediocre do the minimum, then exclaim how easy it is. The exceptional never stop to gloat... they're too busy figuring out new ways to make it even better... - Mr. Lim [more]
Unread 31-01-2015, 16:13
patatepoils patatepoils is offline
FRC #4947
patatepoils is an unknown quantity at this point
Talon srx encoder reset (with breakout)
Hi, how to reset the encoder value with programing. The encoder is pluged directly on the talon srx with a breakout module. I can see the value of the encoder but I don't know if it is posible to reset this value using java code. Thank you!
Unread 31-01-2015, 20:21
ozrien's Avatar
ozrien ozrien is online now
Omar Zrien
AKA: Omar
Re: Talon srx encoder reset (with breakout)
Checkout the setposition function mentioned in the SRX software reference manual. Which type of encoder are you using?
Unread 31-01-2015, 21:05
FRC #4947
Thank you, it work! I use a Hall Effect Two Channel Encoder (am-2816a). The encoder only count positively is it normal? Tank you again!
