Go to Post If time only weren't a factor, everything would be done. - Schnabel [more]
Unread 31-01-2015, 21:05
patatepoils patatepoils is offline
FRC #4947
patatepoils is an unknown quantity at this point
Re: Talon srx encoder reset (with breakout)
Thank you, it work! I use a Hall Effect Two Channel Encoder (am-2816a). The encoder only count positively is it normal? Tank you again!
