Go to Post Roses are red/Violets are blue/I'll write a poem/Once build season's over. - Taylor [more]
Unread 31-01-2015, 20:09
sau sau is offline
FRC #2220 (Blue Twilight)
sau is an unknown quantity at this point
My laptop can't upload code to robot.
Hello, I am having some difficulties connecting my laptop to the robot to upload code. Here is some information:
  • My computer is a Asus Transformer Book T100 running Windows 8.1
  • Our team is using Eclipse to program in Java
  • Every other laptop on my team has been able to upload code, including other laptops running Windows 8.1
  • I have installed and reinstalled the NI Update Suite several times to get the MDNS software
  • Using the driver station software, I can connect to the roborio and enable, disable, look at joystick inputs, etc.
  • When I ping roborio-2220.local, I get back a result saying that I am connected
  • I don't have the exact error with me right now, but it says something along the lines of Assertion Failed Boolean Test, and that MDNS connection failed
  • My firewall has been turned off
Is there something that I am missing? Thanks in advance for your help.
Unread 31-01-2015, 21:26
JamieKilburn JamieKilburn is offline
FRC #0610 (The Coyotes)
Team Role: Driver
JamieKilburn has a spectacular aura aboutJamieKilburn has a spectacular aura about
Re: My laptop can't upload code to robot.
You've probably tried this already, but whenever I get that error, I usually power cycle the robot, which usually resolves the issue.
thatprogrammer's Avatar
thatprogrammer thatprogrammer is offline
AKA: Ahad Bawany
no team (None)
thatprogrammer has a reputation beyond reputethatprogrammer has a reputation beyond reputethatprogrammer has a reputation beyond reputethatprogrammer has a reputation beyond reputethatprogrammer has a reputation beyond reputethatprogrammer has a reputation beyond reputethatprogrammer has a reputation beyond reputethatprogrammer has a reputation beyond reputethatprogrammer has a reputation beyond reputethatprogrammer has a reputation beyond reputethatprogrammer has a reputation beyond repute
What is the error you get when deploying?
Unread 31-01-2015, 21:31
sau sau is offline
The roboRio is connected, the team number is set, and power cycling does not help, and when I try to upload and fail, other people are able to upload immediately after I fail
Buildfile: C:\Users\***\git\BlueTwilightRobot2015\build.xml
Trying to override old definition of task classloader
clean:
   [delete] Deleting directory C:\Users\***\git\BlueTwilightRobot2015\build
   [delete] Deleting directory C:\Users\***\git\BlueTwilightRobot2015\dist
compile:
    [mkdir] Created dir: C:\Users\***\git\BlueTwilightRobot2015\build
     [echo] [athena-compile] Compiling src with classpath=C:\Users\***/wpilib/java/current/lib/WPILib.jar:C:\Users\***/wpilib/java/current/lib/NetworkTables.jar to build
    [javac] Compiling 33 source files to C:\Users\***\git\BlueTwilightRobot2015\build
jar:
     [echo] [athena-jar] Making jar dist/FRCUserProgram.jar.
    [mkdir] Created dir: C:\Users\***\git\BlueTwilightRobot2015\dist
    [mkdir] Created dir: C:\Users\***\git\BlueTwilightRobot2015\build\jars
     [echo] [athena-jar] Copying jars from C:\Users\***/wpilib/java/current/lib/WPILib.jar:C:\Users\***/wpilib/java/current/lib/NetworkTables.jar to build/jars.
     [copy] Copying 2 files to C:\Users\***\git\BlueTwilightRobot2015\build\jars
      [jar] Building jar: C:\Users\***\git\BlueTwilightRobot2015\dist\FRCUserProgram.jar
get-target-ip:
     [echo] Trying Target: roboRIO-2200.local
Unknown host: roboRIO-2200.local
     [echo]  roboRIO not found via mDNS, falling back to static USB
     [echo] roboRIO not found via USB, falling back to static address of 10.22.0.2
BUILD FAILED
C:\Users\***\wpilib\java\current\ant\build.xml:45: Assertion failed boolean test.
roboRIO not found, please check that the roboRIO is connected, imaged and that the team number is set properly in Eclipse
Total time: 15 seconds
Unread 31-01-2015, 21:35
Christopher149 Christopher149 is offline
FRC #0857 (Superior Roboworks) FTC 10723 (SnowBots)
Christopher149 has a reputation beyond reputeChristopher149 has a reputation beyond reputeChristopher149 has a reputation beyond reputeChristopher149 has a reputation beyond reputeChristopher149 has a reputation beyond reputeChristopher149 has a reputation beyond reputeChristopher149 has a reputation beyond reputeChristopher149 has a reputation beyond reputeChristopher149 has a reputation beyond reputeChristopher149 has a reputation beyond reputeChristopher149 has a reputation beyond repute
Are you uploading wired by USB, ethernet, or wirelessly?
2015-present: FTC 10723 mentor
2012-present: 857 mentor
2008-2011: 857 student
2015: Industrial Design, Excellence in Engineering, District Finalist, Archimedes Division (#6 alliance captain)
2014: Judges Award, District Engineering Inspiration, District Finalist, Galileo Division
Unread 31-01-2015, 21:37
ATannahill ATannahill is offline
AKA: Alex Tannahill
Try resetting the team number in eclipse. It seems to think you are team 2200, not 2220.
Thats why the last few lines say roboRIO-2200.local and 10.22.0.2. It should be roboRIO-2220.local and 10.22.20.2.
Unread 31-01-2015, 22:02
sau sau is offline
Hi, when I go to my team number in preferences, it is 2220, but when I click restore defaults, it changes my number to 2200. I think that this is because when I first typed in my team number, I made a typo, and typed 2200 instead of 2220.
I tried changing my team number multiple times, and it always gives me an ArrayOutOfBoundsException, and it sometimes gives me an Unhandled event loop exception as well.
Is there a way I can change my default team to 2220?
Unread 31-01-2015, 22:17
AKA: Alex Tannahill
From: http://wpilib.screenstepslive.com/s/...to-the-roborio
Verify ... your team number is set properly in Eclipse (Window->Preferences->WPILib Preferences).
I do not know any further than that. The best I can suggest is wipe and re-install the FRC update suite.
