Go to Post *puts on flame suit and goes to hide in the corner* :D - Wayne Doenges [more]
Unread 31-01-2015, 13:30
ironmare ironmare is offline
FRC #5072
ironmare is an unknown quantity at this point
Program a dead zone?
Please help. We are using an xbox 360 usb joystick with mecanum wheels. After deploying our program (not touching the thumbstick) the wheels are spinning slowly on their own. We flick the left thumbstick and can get some wheels to stop every so often. We need help in seeing some LabView code to create a dead zone with a 0.1 so that it disregards the off center joystick input. Thank you!
Unread 31-01-2015, 14:11
Re: Program a dead zone?
Here is one example.
A drawback to this one is that it will start motor power at the deadband value. Not necessarily an issue with drive motors that don't begin moving before .3, but more of an issue with mechanism motors that have much lower resistance to movement.
It can be rescaled with a little more trouble.
P.S.
Here is an example of rescaling.
ID:	18075  Click image for larger version
Unread 31-01-2015, 15:35
This is the block diagram of the Deadband.vi we use. It subtracts the deadband size from the input value. If the result is less than zero it keeps it at zero. Other code can use the "In Deadband?" output to do things like maintain heading or activate a brake.
Unread 31-01-2015, 15:53
adciv adciv is offline
One Eyed Man
FRC #0836 (RoboBees)
Try calibrating your motor controllers.
Unread 01-02-2015, 00:56
pastelpony's Avatar
pastelpony pastelpony is offline
Programmer/Electrical
AKA: Zach M
FRC #3525 (Nuts and Bolts of Fury)
pastelpony will become famous soon enough
We had the same issue. In the end, we found that calibrating the actual Xbox 360 controller led to no sudden jerks or movement of our mecanums. You might also want to calibrate your motor controllers.
Team 3525 Head Programmer (2014- ) - Java (Formerly LabVIEW)
Unread 01-02-2015, 20:53
Sohaib's Avatar
Sohaib Sohaib is offline
AKA: Sohaib Nadeem
FRC #5036 (The Robo Devils)
Sohaib is a glorious beacon of lightSohaib is a glorious beacon of lightSohaib is a glorious beacon of lightSohaib is a glorious beacon of lightSohaib is a glorious beacon of light
If you disconnect your controller, and reconnect it, it should be centered. I don't know about the Xbox controller, but with the F310s this seems to fix the issue.
Going to advocate calibrating your motor controllers.
If you're using the Talon SR/SRX or Victor SP, speed controllers, they have a built in "deadband" of 4%. The Victor 888 has one of 5.4% and the Jaguar of 5.5%.
2014 Season:
- Drive Coach
- Rookie All-Star Award (GTR-E)
2015 Season:
- Driver
- Deans List Semi-Finalist (GTR-E)
2016 Season:
- Driver
- Alliance Captain (GTR-E)
Unread 02-02-2015, 13:50
FRC #5072
Thank you all for your help, re-coding the programming with the dead zone coding using your suggestions above worked!
Unread 06-02-2015, 14:41
Skyehawk's Avatar
Skyehawk Skyehawk is online now
Nuts N' Bolts
AKA: Skye Leake
FRC #0876 (Thunder Robotics)
Skyehawk is a name known to allSkyehawk is a name known to allSkyehawk is a name known to allSkyehawk is a name known to allSkyehawk is a name known to allSkyehawk is a name known to all
quick question: How do you export labview code so you can just drop it in?
Unread 06-02-2015, 14:49
Highlight what you want to copy.
Choose
Edit -> Create VI Snippet From Selection
A Save dialog appears to save it as a png.
