Go to Post Sorry, during my fluid mechanics lectures on drag I must have been designing a gearbox in my mind. FRC season will do that. - sanddrag [more]
Unread 28-01-2015, 00:20
nickmcski nickmcski is offline
AKA: Nicholas McCurry
FRC #1482 (Grandin Ghosts)
nickmcski has a spectacular aura aboutnickmcski has a spectacular aura aboutnickmcski has a spectacular aura about
Re: Unable to get SmartDashboard Source
Originally Posted by lopsided98 View Post
This problem has still not been resolved. A link to allow anonymous access to WPILib was released, could the same thing be done for the Smart Dashboard?
I tried using git clone "https://usfirst.collab.net/gerrit/smart_dashboard" (the same link used to access WPILib, but with the project name changed), but it gives me "fatal: remote error: Git access forbidden" when I try to login.
Hi lopsided, I was talking to Patrick a while ago (He manages the repositories) and hey told me been having trouble getting the official repositories permission set correctly. He just told me to use his public mirrors which are updated more often than the official CollabNet reposotories(he also linked them above). https://bitbucket.org/byteit101/sfx https://bitbucket.org/byteit101/sfxlib https://bitbucket.org/byteit101/sfxmeta https://bitbucket.org/byteit101/sfxcv and https://bitbucket.org/byteit101/fx-livewindow
But I must warn you in advance I recently set up my development environment and I found it really hard to setup my development environment and I had to email Patrick multiple times about multiple problems I had getting setup. I mostly followed this guide here but it is slightly outdated so I will try to get around to updating it and posting the problems I had and how to get around them for anyone else who wants to compile the code.
Unread 28-01-2015, 14:40
Dartmouth 2020
AKA: lopsided98
FRC #2084 (Robots by the C)
I know about those, but they are for the new SmartDashboard FX, not the original one.
Unread 01-02-2015, 09:27
java4first java4first is offline
(Java) Programming Mentor
AKA: Stu
FRC #0501 (Power Knights)
java4first is an unknown quantity at this point
I would really like to get the source for the old one as well ... At this point I would settle for just an archive of the source - I can probably figure out how to get it built within Eclipse. In return, I will find the bug that causes it to write a zero length configuration file every now and then and cause you to start all over again.
Unread 01-02-2015, 09:38
Have you tried the methods on the project homepage? https://usfirst.collab.net/sf/projects/smartdashboard/
Unread 01-02-2015, 12:54
byteit101's Avatar
WPILib maintainer (WPI)
AKA: Patrick Plenefisch
Public mirror!
https://bitbucket.org/byteit101/oldsmartdashboard
I will try to keep this up to date, but as I no longer develop it (currently working on SFX) I can't make many promises of how up to date it will stay. At the very least, this is the current source as of 2 mintues ago
Watchdog.Kill();
Unread 01-02-2015, 13:02
Dartmouth 2020
AKA: lopsided98
Thanks!
Unread 13-02-2015, 20:45
ArthurA's Avatar
ArthurA ArthurA is offline
I think that I'm registered???
FRC #4774 (The DropBears)
ArthurA has a spectacular aura aboutArthurA has a spectacular aura about
Bump
EDIT: Sorry I didn't realize that there was a page two :/
