RoboRIO red comm light, not accepting code?
Our PDP is giving us an orange light, and our roboRIO is giving us a red comm light. When we deploy code, eclipse reports it as deployed, but the roboRIO does not seem to get the new code. The ni web browser does NOT report a sticky fault.
Technical Details: RoboRIO is imaged Can ID's are correct No fuses appear to be blown Driver station can connect, but does not report any code |
Re: RoboRIO red comm light, not accepting code?
Is the roboRIO perhaps set to not run the user program on startup?
Commenting out the auto code I had added fixed the red comm light. Does anyone mind reading through the code to see what might be causing the error?
void AutonomousInit()
//gyro->Reset();
void AutonomousPeriodic()
SmartDashboard::PutNumber("Gyro Angle:", Angle);
if (automode == 1)
gyro->GetAngle();
if (Angle == 90)
robottime = false;
} else {
robottime = true;
if(robottime == true)
robot->Drive(0,-1);
if (robottime == false)
robot->Drive(0,-1);
if (automode == 2)
gyro->GetAngle();
if (Angle == 45)
robottime = false;
} else {
robottime = true;
if (robottime == true)
robot->Drive(0, -.5);
robot->Drive(0,0);
I'd wager that either robot or gyro is an uninitialized pointer.
#include "WPILib.h"
class Robot: public IterativeRobot
private:
//Initializing livewindow
LiveWindow *lw;
//Initializing stick
Joystick *stick;
//Initializing the Chassis parts
Talon *kFrontLeftMotor;
Talon *kFrontRightMotor;
RobotDrive *robot;
Relay *Fan;
DoubleSolenoid *shifter;
Encoder *ChassisEnc;
Encoder *OtherEnc;
//Initializing the values for Cheesy Drive
float Rotation;
float Acceleration;
float rightMultiplier;
float leftMultiplier;
double automode;
Gyro *gyro;
bool robottime;
double Angle;
void RobotInit()
SmartDashboard::init();
lw = LiveWindow::GetInstance();
stick = new Joystick(0);
kFrontLeftMotor = new Talon(0);
kFrontRightMotor = new Talon(1);
robot = new RobotDrive(kFrontRightMotor, kFrontLeftMotor);
Fan = new Relay (3);
/* Setting the shifter as a DoubleSolenoid
* Because we're using both pistons off of
* one Double Solenoid
shifter = new DoubleSolenoid (0,1);
ChassisEnc = new Encoder (0,1, false, Encoder::EncodingType::k4X);
OtherEnc= new Encoder (8,9, false, Encoder::EncodingType::k4X);
//Setting it so the fan is off by default
Fan->Set(Relay::kOff);
//Setting the Rotation and Accel values
Rotation = stick->GetRawAxis(1);
Acceleration = stick->GetRawAxis(3);
/*Setting the multipliers
* so that they don't allow
* a robot to go full forward
* while going full turn
rightMultiplier = Rotation + Acceleration;
leftMultiplier = Rotation - Acceleration;
//Setting the shifter to Low Gear
shifter->Set(DoubleSolenoid::kReverse);
robot->SetInvertedMotor(RobotDrive::kFrontLeftMotor, true);
robot->SetInvertedMotor(RobotDrive::kFrontRightMotor, true);
ChassisEnc->SetDistancePerPulse(11.04);
OtherEnc->SetDistancePerPulse(11.04);
/*gyro = new Gyro (2);
Angle = gyro->GetAngle();
if (stick->GetRawButton(1))
automode = 1;
if (stick->GetRawButton(2))
The gyro constructor is commented out in the code you just posted, and your gyro appears to be on a channel that won't work. It needs to be on Channels 0 or 1.
#7
Yeah, it was commented out after deploying, along with the auto code. Confused about the second sentence, doesn't the gyro have four ports it can plug into? Sorry for slow replies BTW, school WiFi does not let me post on chief Delphi, other than starting threads.
#8
See Gyro: http://first.wpi.edu/FRC/roborio/rel...classGyro.html And AnalogInput kAccumulatorChannels : http://first.wpi.edu/FRC/roborio/rel...alogInput.html Last edited by RufflesRidge : 01-02-2015 at 23:10. |
#9
Try looking at the logs on the Dashboard. Usually they'll give you an error.
#10
Changing gyro port to 1 fixed it! Thanks. The only thing I can't figure out is how to have multiple auto modes without using the selectable chooser. It seems that only works with command based robot?
