Go to Post Half your robot could be broken, some drive chains snapped, a drive motor burned out, etc... and your WCD will still be trucking. - AdamHeard [more]
Unread 31-01-2015, 22:54
MrRoboSteve MrRoboSteve is offline
AKA: Steve Peterson
FRC #3081 (Kennedy RoboEagles)
MrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond repute
pic: 3081 RoboEagles KR-15905 Electronics Unit
Unread 31-01-2015, 22:55
xXhunter47Xx's Avatar
xXhunter47Xx xXhunter47Xx is offline
Lord of Lazy
AKA: Austin $wagmaster1337
FRC #4738 (Patribots)
xXhunter47Xx will become famous soon enough
Re: pic: 3081 RoboEagles KR-15905 Electronics Unit
I'm interested on the wire management on this. It also looks like it's hinged but the way the jaguar is mounted it doesn't look like it closes.
College sux yo
Unread 31-01-2015, 23:01
Zebra_Fact_Man's Avatar
Zebra_Fact_Man Zebra_Fact_Man is offline
]\/[ Go Blue!
AKA: Solomon
FRC #1076 (Pi Hi Samurai)
Zebra_Fact_Man has a brilliant futureZebra_Fact_Man has a brilliant futureZebra_Fact_Man has a brilliant futureZebra_Fact_Man has a brilliant futureZebra_Fact_Man has a brilliant futureZebra_Fact_Man has a brilliant futureZebra_Fact_Man has a brilliant futureZebra_Fact_Man has a brilliant futureZebra_Fact_Man has a brilliant futureZebra_Fact_Man has a brilliant futureZebra_Fact_Man has a brilliant future
Curious how ventilation is going to work. Them electronics need to breathe!
My Journey in FIRST:
Mentor/Coach/Engineer
2014-2017: Team 1076 - Pi Hi Samurai
____ 2014: Team 5220 - The Rockets
2009-2014: Team 313 - The Bionic Union/Bionic Zebras
Student
2006-2009: Team 313 - The Bionic Union
Unread 31-01-2015, 23:37
orangemoore orangemoore is offline
AKA: Roger Moore
FRC #3135 (Robotic Colonels)
orangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond repute
It looks like it might be a nightmare to trouble shoot
Stronghold
Student 2013-2016
3135 -- Robotic Colonels
3507 -- Robotheosis (FTC)
Unread 01-02-2015, 11:41
Tungrus Tungrus is offline
Tungrus is just really niceTungrus is just really niceTungrus is just really niceTungrus is just really nice
Trouble shoot may be a bit difficult but not a nightmare.
Hope the main circuit breaker is easily accessible. If I had to do this, I would make it in polycarbonate (lexan etc) to prevent electrical noise around roboRIO (I am not a expert but would cautious).
Unread 01-02-2015, 14:57
PAR_WIG1350's Avatar
AKA: Alan Wells
FRC #1350 (Rambots)
It appears that the pivot is placed a bit above the top of the jaguar on the near half and above the level of the PDP breakers on the other half. There should be clearance, but I can't easily tell how much there will be.
Unread 01-02-2015, 21:55
AKA: Steve Peterson
Our goal with this design was:
1. Allow for electronics build off of robot
2. Electronics components either covered, mounted upside down, or mounted vertically
3. Easy to reach connectors on PDB from the side
4. Conserve space
It's made with 0.050 6061-T6 aluminum sheet. The top and bottom tabs on each side are fastened together with #8 screws. During the build, we install just the bottom screws, and can lay it almost completely open on the workbench. On the robot it can open about 30 degrees -- wide enough to get in to swap speed controllers and change wiring. If we need to open it further, the battery box next to it is fastened with 4 screws and is easily removed. The PDB and breaker are screwed to the box -- everything else is attached with Velcro
Here's a view of it from the side -- plenty of room for the Jag in there.
http://1drv.ms/169nz02
During the build, we did switch to use Talons inside there for five of our motors, as the layout worked better. We also moved the PDB up slightly to avoid interfering with the machine screws that attach it to the chassis. Because of that, we moved the circuit breaker to the outside of the box, "behind" the PDB.
I'm not super concerned about heat buildup. The unit is built like a chimney with an open top, bottom. The sides each have 16 square inches of opening for air to flow in. It's made out of aluminum, which is great at dissipating heat.
Here's an as-built photo. It shows the wire management.
https://twitter.com/MrRoboSteve/stat...62383760760832
2016-17 events: 10000 Lakes Regional, Northern Lights Regional, FTC Burnsville Qualifying Tournament
2011 - present · FRC 3081 Kennedy RoboEagles mentor
2013 - present · event volunteer at 10000 Lakes Regional, Northern Lights Regional, North Star Regional, Lake Superior Regional, Minnesota State Tournament, PNW District 4 Glacier Peak, MN FTC, CMP
http://twitter.com/MrRoboSteve · www.linkedin.com/in/speterson
