Go to Post They see us come into school looking like zombies, and they know that some people start smelling like chain lube and such...but for the most part, they don't realize that for a lot of us, there is a deep commitment to our team that we do a very large amount of work for that team. - JakeGallagher [more]
Unread 01-02-2015, 18:34
tomy tomy is offline
FRC #3038 (I.C.E. Robotics)
tomy has a spectacular aura abouttomy has a spectacular aura about
Would it be legal/possible?
I was wondering if it was possible to take 12V RGB LED Strip and plug it directly into the PD board to light up the robot. The RGB Strip has a 12V connection but I cant seem to find the ground. Is this legal / possible?
Unread 01-02-2015, 18:36
Re: Would it be legal/possible?
You're going to need to find the ground before you can really do anything. Do you have a part number/datasheet?
Unread 01-02-2015, 18:38
Dartmouth 2020
AKA: lopsided98
FRC #2084 (Robots by the C)
You should be fine as long as they are simply dumb (ie. not digitally controlled) strips. Keep in mind that they will dim when your battery voltage drops.
I don't really understand what you mean by saying you can't find the ground. The LED strip should have two wires, one black and one red. They should go into the correspondingly colored ports on the PDP. A part number/link would be helpful.
Unread 01-02-2015, 18:40
This is the exact LED strip I have:
http://www.adafruit.com/products/285...roducts_id=285
Unread 01-02-2015, 18:48
Dartmouth 2020
AKA: lopsided98
If you just want it to show a single color, you should just be able to plug the +12v wire into the positive on the PDP, and the R, G, and/or B wires (in any combination) into the negative on the PDP.
It would want more control, I would recommend using an Arduino and some transistors to control the channels with PWM. You could also try using the PWM outputs on the roboRIO, but their low frequency might cause come flickering.
This Adafruit tutorial should help with wiring the transistors to an Arduino (or to the roboRIO PWM outputs).
Unread 01-02-2015, 18:50
Mr V's Avatar
Mr V Mr V is offline
FRC #5588 (Reign)
There are 3 ground wires, one for each of the different LEDs in each light. IE one for Red, one for Green and one for Blue. Depending on which one(s) you ground and how frequently they are cycled on and off you'll get the different colors.
How it all works is explained in the first paragraph of the description.
Unread 01-02-2015, 18:51
So it would be legal to wire it directly to the PD Board
Unread 01-02-2015, 18:56
kgzak's Avatar
kgzak kgzak is online now
AKA: Kris
FRC #4392 (Decievers) FRC #2075 (Enigma)
kgzak is a splendid one to beholdkgzak is a splendid one to beholdkgzak is a splendid one to beholdkgzak is a splendid one to beholdkgzak is a splendid one to beholdkgzak is a splendid one to beholdkgzak is a splendid one to behold
Those are common anode LEDs meaning that they share a common 12v and have 3 different grounds. One for each color (Red, Green, Blue). Adafruit has a tutorial that can teach you everything you need to know here:https://learn.adafruit.com/rgb-led-strips/overview
Unread 01-02-2015, 20:22
Sohaib's Avatar
Sohaib Sohaib is offline
AKA: Sohaib Nadeem
FRC #5036 (The Robo Devils)
Sohaib is a glorious beacon of lightSohaib is a glorious beacon of lightSohaib is a glorious beacon of lightSohaib is a glorious beacon of lightSohaib is a glorious beacon of light
You can always connect it to the VRM to alleviate this. The VRM will to some degree regulate the voltage so that when your battery may not be providing a constant 12v, the VRM will do it for you.
2014 Season:
- Drive Coach
- Rookie All-Star Award (GTR-E)
2015 Season:
- Driver
- Deans List Semi-Finalist (GTR-E)
2016 Season:
- Driver
- Alliance Captain (GTR-E)
Unread 01-02-2015, 20:24
Dartmouth 2020
AKA: lopsided98
In this case though, you will need to make sure to not exceed 2 amps. We didn't have that many LEDs last year, but when they were displaying bright white, we used around 3 amps.
Unread 01-02-2015, 20:26
Sohaib's Avatar
AKA: Sohaib Nadeem
The highest current outputs labelled on the VRM are 2A.
2014 Season:
- Drive Coach
2015 Season:
- Driver
2016 Season:
- Driver
Unread 01-02-2015, 20:27
Dartmouth 2020
AKA: lopsided98
Yes, that is why I warned about not exceeding 2 amps.
Unread 01-02-2015, 20:56
Tungrus Tungrus is offline
Tungrus is a jewel in the roughTungrus is a jewel in the roughTungrus is a jewel in the roughTungrus is a jewel in the rough
Just a reminder, VRM's 2A rating is peak, nominal is 1.5A.
Unread 01-02-2015, 20:59
What happens if you exceed the 2amp out put on the VRM or can you?
Unread 01-02-2015, 21:03
Per the VRM User Guide it's 1.5A continuous, 2A peak.
In Beta I think I remember the result of overloading it for at least one team being a cooked VRM.
