Go to Post If you're the smartest person in the room, you're in the wrong room - Ian Curtis [more]
Unread 20-10-2014, 15:46
Bruceb's Avatar
Bruceb Bruceb is offline
FRC #0706 (Cyberhawks)
Bruceb is a splendid one to beholdBruceb is a splendid one to beholdBruceb is a splendid one to beholdBruceb is a splendid one to beholdBruceb is a splendid one to beholdBruceb is a splendid one to beholdBruceb is a splendid one to behold
Re: CNC Aluminum: Recommended Speeds/Bits?
Why do you use both up spiral and straight bits?
Mentor Team 706 The CyberHawks
2010 Wisconsin Regional Rockwell Automation Innovation in Control Award
2010 Wisconsin Regional Finalist
2013 Buckeye Regional Finalist
2014 Superior Regional Industrial Design Award
2014 Superior Regional Finalist
2014 Wisconsin Regional Finalist
2014 Wisconsin Motorola Quality Award
2015 Wisconsin Regional Motorola Quality Award
2015 Queen City Creativity Award
2016 Buckeye Regional Finalist
2016 Wisconsin Regional Finalist
2016 Wisconsin Regional Industrial Safety Award
2016 Wisconsin Regional Excellence in Engineering Award
https://www.youtube.com/user/Cyberhawks706
Unread 20-10-2014, 16:39
JamesCH95's Avatar
Hardcore Dork
AKA: JCH
FRC #0095 (The Grasshoppers)
Spiral bits are used for extracting chips from the cutting area. This is great for contouring holes, slots, pockets, and other features where chips tend to build up.
Straight bits, also called edging bits, won't extra chips as efficiently (or at all) but they also won't lift up on the part they're cutting. This makes them useful for trimming the edges of parts as there is plenty of room for the chips to go and they don't lift up on the part's edge, potentially causing chatter.
Unread 22-10-2014, 20:10
Andy Brockway Andy Brockway is offline
Engineer
FRC #0716 (Who'sCTEKS)
Andy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond repute
I have a really old CNC router with a standard wood router running at 30,000 rpm. I have had success cutting aluminum with an 1/8" diam straight router bit at 10 ipm, .005 DOC. This is slow but I do not run coolant and it does not clog the bit.
Andy Brockway
Team 716, The Who'sCTEKS
Unread 29-01-2015, 01:02
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
I have to post back in this thread to thank all those that recommended the Onsrud single flute bits. It's been a complete night and day difference. It essentially made the difference between our router not being able to cut aluminum at all, and now cutting it beautifully.
I was able to pocket with a 1/4" bit, 20,000 RPM, .090 DOC, 15% stepover, 84 IPM, and it worked very well.
Thanks again!
Unread 01-02-2015, 21:19
Odin Odin is offline
AKA: Antoine
FRC #2410 (Metal Mustang Robotics)
Odin is an unknown quantity at this point
We usually use Onsrud 1/4 and 1/8 inch single flute with our feed rates being 60 ipm (1/4 in) and 35 ipm (1/8 in), a plunge rate of 15 ipm for both bits, and finally a spindle speed of 12000 rpm. This is all done on a techno router
