Go to Post I guess everyone cant play real defense, like actually pushing the other robot instead of ramming it with the intent to destroy. - Dillon Compton [more]
Unread 01-02-2015, 17:31
terps1 terps1 is offline
terps1 is an unknown quantity at this point
Sensor to measure velocity
Hi everyone,
I am new to electronics and new to the forum.
I am wanting to develop a device similar to this (for personal use)...
http://www.tendosports.com/TENDO-Units.html
I am having a tough time designing the actual device (havent touched arduino yet)
My idea is this:
Measure bar average and peak velocity.
Specs:
String length up to 3m
Digital output from rotary sensor
Minimal tension on the retractable string (3-6 oz)
High accuracy
Keeping cost to minimum ($100-$150) for materials only.
So far my thoughts are
microcontroller
String pot or rotary encoder
tensioner as in a id badge retractor
fishing line or thin durable string (teflon coated)
Is this doable? Any advice?
Thanks
Unread 01-02-2015, 22:35
GeeTwo's Avatar
GeeTwo GeeTwo is offline
Technical Director
AKA: Gus Michel II
FRC #3946 (Tiger Robotics)
Re: Sensor to measure velocity
It certainly does sound doable, at that price. We actually built a "tape measure potentiometer" for our robot with a 73-inch capacity for under $30 using COTS parts and a drill press. This cost did not include the RoboRIO, but it could just as easily have been an arduino. As you can see in the attached photos, we used a voltmeter to get analog readings before we ever hooked it to the 'RIO. If you use a 10-turn potentiometer (the costs go up considerably for higher number of turns), you'll need a drum/reel with at least a 30cm circumference, or about 10cm in diameter.
With the low retraction force, you'll need to may wind up with some "bird-nesting" on the reel if the load moves quickly towards the sensor.
OBTW, there is already a COTS item on AndyMark which looks similar to what you want, though it only has about a tenth of the extension:
http://www.andymark.com/product-p/am-2674.htm
ID:	18088  Click image for larger version
ID:	18089  Click image for larger version
