Go to Post What about marriages ended by FIRST. I know that by Presidents Day my wife is not real happy with me :) - IndySam [more]
Unread 01-02-2015, 11:40
ParisDakar's Avatar
ParisDakar ParisDakar is offline
Lead Welding Mentor
AKA: Keith Williams
FRC #1640
ParisDakar has a spectacular aura aboutParisDakar has a spectacular aura aboutParisDakar has a spectacular aura about
1640 Automated Welding
One of our critical drive system parts requires a circular weld. We automate it and do it in house. Requires a weld as good as humanly possible, so we eliminate the human.
https://www.youtube.com/watch?v=jxa4EXiPEHg
Unread 01-02-2015, 11:57
ParisDakar's Avatar
Lead Welding Mentor
AKA: Keith Williams
FRC #1640
Re: 1640 Automated Welding
The finished part.
http://wiki.team1640.com/images/8/84/DB11_150131-6.jpg
Unread 01-02-2015, 16:52
Foster Foster is offline
Engineering Program Management
VRC #8081 (STEMRobotics)
Foster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond repute
Very pretty stacked dimes!
Clever solution to a hard problem, looks like you could do the tubes for Prime and Deux in under an hour.
Foster - VEX Delaware - 17 teams -- Chief Roboteer STEMRobotics.org
2010 - Mentor of the Year - VEX Clean Sweep World Championship
2006-2016, a decade of doing VEX, time really flies while having fun
Downingtown Area Robotics Web site and VEXMen Team Site come see what we can do for you.
Unread 01-02-2015, 23:07
Oldbikerider's Avatar
Oldbikerider Oldbikerider is offline
AKA: Graham
FRC #3132 (Thunder Down Under)
Oldbikerider will become famous soon enough
Nice. Care to share how you arranged the welding lathe?
Graham
FIRST® TEAM 3132
Thunder Down Under
Sydney, Australia
Unread 02-02-2015, 22:52
ParisDakar's Avatar
Lead Welding Mentor
AKA: Keith Williams
FRC #1640
The turntable is one I built for my own shop, for welding, cutting, & positioning round assemblies. Runs on 12v, with an adjustable speed control, either constant on, or turned on via a thumb switch. We set the turntable next to the welding table and clamp the spoolgun onto the table leg, pointing down onto the part. Part is held up by three right angle magnets. Takes a bit of adjustment to get the part turning true. Then I have a student pull the trigger on the gun, while I hit the turntable button.
I used to do the welds myself by hand, but this is much better. Lets the students take part in the process. We can knock all 8 of them out in 15 minutes. It's fun.
Unread 03-02-2015, 02:34
lukedude43 lukedude43 is offline
Doer of stuff and things
AKA: Luke Reinert
FRC #4030 (NullPointerException)
lukedude43 will become famous soon enoughlukedude43 will become famous soon enough
I was wondering what the best way to weld those would be, I thinkyou guys found it. Here's our solution to the same problem http://imgur.com/E9axpVI. We just thought that the shotgun approach to a bunch of machine shops in the area would be easier than finding someone who could weld them on short notice, turns out the first shop we talked to was more than happy to donate the materials and time.
Unread 03-02-2015, 21:24
AKA: Graham
Thanks for the information Keith. I'm sure our team will jump at the opportunity to try this. But this year our robot is mostly aluminium, so maybe next year.
Graham.
Graham
FIRST® TEAM 3132
Thunder Down Under
Sydney, Australia
Unread 04-02-2015, 09:00
ParisDakar's Avatar
Lead Welding Mentor
AKA: Keith Williams
FRC #1640
A welding turntable/positioner is a good off season project, useful for many things. Since even used ones were expensive, I built mine out of "junk". I can post some pics if you like.
Unread 04-02-2015, 09:16
Bochek's Avatar
Bochek Bochek is offline
AKA: Adam Bochek
FRC #2200 (MMRambotics)
Bochek has much to be proud ofBochek has much to be proud ofBochek has much to be proud ofBochek has much to be proud ofBochek has much to be proud ofBochek has much to be proud ofBochek has much to be proud ofBochek has much to be proud ofBochek has much to be proud ofBochek has much to be proud of
I would love to see pics. I've been thinking about building one for myself for a while now. Just haven't gotten around to it.
Adam Bochek - FRC 2200
http://www.mmrambotics.com
http://www.watchfirstnow.com
Unread 04-02-2015, 13:50
Addison4300's Avatar
Addison4300 Addison4300 is offline
FRC is love, FRC is life
AKA: Addison
FRC #4300 (The Lion Kings)
Addison4300 is on a distinguished road
Wow, I feel a bit blind now. However, that's a very nice way to easily do that. Great Thinking!
Unread 04-02-2015, 22:20
ParisDakar's Avatar
Lead Welding Mentor
AKA: Keith Williams
FRC #1640
This is the turntable. The hub & spindle is from a 3000 lb trailer axle. The round top is 1/2" thick by 14" diameter. Drive motor is a cordless drill motor/clutch/chuck. Right angle gearbox is from an angle grinder. Speed control was 10 bucks new on Ebay. Legs are about 18" long with leveling adjusters at the ends. I welded a 1/2 inch plate to the spindle and turned it down to create a flange. 4 bolts hold the top on, or any other thing I might want to bolt to it.
Items to note:
The motor and speed control is electrically isolated via the plastic control box, rubber motor sleeve and plastic sprocket on the spindle. The unit runs on any 12v power source, I did not want house current in it in case anything went awry.
A copper wiper on the spindle conducts welding current around the hub bearings.
The input shaft to the angle grinder is a std 1/4" hex drive (welded on) so I can use any gearmotor by attaching a drill coupler to it. I found I needed different motors due to the extremely slow rotation required for some jobs. Cutting down a friend's 36" round steel fire pit with a torch required a 5 minute rotation, or about 1/16th of a rpm
All welds on the hub required preheat, nickel rods and slow cooling, as the hub is iron.
Runout at the edge of the table is about .009", one of the benefits of using a substantial hub and spindle. I wouldn't hesitate to put 1000 lb on it.
Flexibility and modularity were my design goals (and of course cheapness). Feel free to ask any questions.
http://wiki.team1640.com/index.php?t...Turntable1.JPG
http://wiki.team1640.com/index.php?t...Turntable2.JPG
