Go to Post I'll try to sum up the icon and compile thing quickly so as not to interrupt the design of SkyNet. - Greg McKaskle [more]
Unread 30-01-2015, 15:28
anthonygraff24 anthonygraff24 is offline
FRC #2872 (CyberCats)
anthonygraff24 is an unknown quantity at this point
Locking a Motor
If I set a motor to 0 power, will that lock the motor? We are picking up the recycling bin with a winch and pulley mechanism, so if the motor driving the winch is allowed to free-spool we are worried that when the weight of the recycling bin is placed on the free-spooling winch the bin will move down. I'm not sure if simply setting the motor to 0 power will lock the motor, or if there is another command to lock a motor.
Unread 30-01-2015, 15:35
kgzak's Avatar
kgzak kgzak is online now
AKA: Kris
FRC #4392 (Decievers) FRC #2075 (Enigma)
kgzak is a splendid one to beholdkgzak is a splendid one to beholdkgzak is a splendid one to beholdkgzak is a splendid one to beholdkgzak is a splendid one to beholdkgzak is a splendid one to beholdkgzak is a splendid one to behold
Re: Locking a Motor
No, setting the output of a motor to 0 will not lock the motor in place, it will just not output anything to the motor. The motor controllers have a brake/coast jumper/function that can cause the motor to brake which may or may not be enough to keep the motor from moving. You could also drive the motor at a very slow speed that counteracts the force of the totes. otherwise a simple mechanical brake can be used to hold the motor in place.
Unread 30-01-2015, 19:13
ozrien's Avatar
ozrien ozrien is online now
Omar Zrien
AKA: Omar
Re: Locking a Motor
kgzak is correct. Talon SR, Jaguar, and Victor 888s have a brake/coast jumper.
Victor SP has a button to select brake vs coast in neutral mode.
Talon SRX has a button to select brake vs coast, and can be software selected over CAN bus.
See Talon SR User's Manual for more info for original Talon and Talon SR.
See Talon SRX User's Guide for more info.
See Victor SP's Quick Start for more info.
"Brake during neutral" simply means that when 0 the motor leads are connected together. I wouldn't say it's "locked", but the generated back electromotive force will resist the rotation of the motor.
Unread 30-01-2015, 19:26
Re: Locking a Motor
The braking torque is proportional to speed.
Unread 01-02-2015, 22:33
DonRotolo's Avatar
Back to humble
FRC #0832
Re: Locking a Motor
Yes, because the 'brake' is simply a short across the motor which is acting as a generator, causing the generator to have a load which slows it down. But only when it is moving, and when moving slow the effect is minimal.
Anthony, you need to find a different solution to lock the motor in place, in general adding a little power to hold the motor still is not good for the motor (it gets hot, sometimes too hot).
Unread 02-02-2015, 00:31
Poseidon5817's Avatar
Poseidon5817 Poseidon5817 is offline
Founder and CEO, DeadMemes Studios
AKA: Mitchel Stokes
FRC #5817 (Uni-Rex)
Poseidon5817 has much to be proud ofPoseidon5817 has much to be proud ofPoseidon5817 has much to be proud ofPoseidon5817 has much to be proud ofPoseidon5817 has much to be proud ofPoseidon5817 has much to be proud ofPoseidon5817 has much to be proud ofPoseidon5817 has much to be proud ofPoseidon5817 has much to be proud ofPoseidon5817 has much to be proud of
Re: Locking a Motor
You could do it mechanically or set it to hold its position with a PID loop.
My FRC History:
2014 - Team 1671: Central Valley Regional Finalist and Chairman's Award Winner, Sacramento Regional Finalist, Archimedes Quarterfinalist
2015 - Team 1671: Central Valley Regional Semifinalist, Sacramento Regional Semifinalist and Chairman's Award Winner, Newton Winner, Einstein Winner
2016 - Team 5817: Central Valley Regional Finalist and Rookie All-Star, Orange County Regional Quarterfinalist and Rookie All-Star, Newton Division
2017 - Team 5817: Return of the bench grinder
Unread 02-02-2015, 08:41
DonRotolo's Avatar
Back to humble
FRC #0832
Re: Locking a Motor
Mechanically is a good idea. PID loop maybe not so much.
Unread 02-02-2015, 10:14
Michael Hill's Avatar
Re: Locking a Motor
I like mechanical. Take a look at the CAD of 118's robot from a couple years ago (don't remember exactly which year). They had a mechanical gear brake in their drive system.
