Go to Post Just a note, there are 2,534 teams registered and competing in FRC this year. That means that there are 2,533 teams being run in a manner entirely different than your own. - Jay Trzaskos [more]
Unread 01-02-2015, 01:10
Jpatterson1710's Avatar
Jpatterson1710 Jpatterson1710 is offline
AKA: Josh Patterson
FRC #1710 (Ravonics Revolution)
Jpatterson1710 has a spectacular aura aboutJpatterson1710 has a spectacular aura aboutJpatterson1710 has a spectacular aura about
1710s Robot
Meet our practice bot, QuikStack. Still needs a competed mechanism for the bins, but here's a video of one of our first cycles this year. Stay tuned for the completed QuikStack, and the competition bot, Decas.
http://youtu.be/b-eKpxStnas
2012-2014 Mechanical Team FRC 1710
2014-2015 Chief Operations Officer FRC 1710
2016-Present FTAA
Unread 01-02-2015, 01:19
JorgeReyes JorgeReyes is offline
Team Captain
FRC #2002 (Tualatin Robotics)
JorgeReyes is an unknown quantity at this point
Re: 1710s Robot
We have a very similar robot. Did you guys power the front omni wheels and also your tote lifter looks like it barely clears totes so is there a seperate bin lifter?
Unread 01-02-2015, 01:28
asid61's Avatar
asid61 asid61 is offline
AKA: Anand Rajamani
FRC #1072 (MVRT)
Re: 1710s Robot
Looks pretty slick. You could increase your intake and elevator speed if you have weight left to add motors or just decrease the gear ratio.
Your driver looks pretty good too. Good luck!
Unread 01-02-2015, 01:48
samfruth's Avatar
samfruth samfruth is offline
Team Role: Driver
samfruth will become famous soon enough
Re: 1710s Robot
The front omnis aren't powered and we are working on a way to pick up bins at the moment. We are trying to make it all one mechanism, idealy.
Unread 01-02-2015, 01:52
samfruth's Avatar
Team Role: Driver
Re: 1710s Robot
Thanks for the advice! We have the motors turned down in code as well. If i recall correctly half speed.
Sorry for double posting, phone struggles.
Unread 01-02-2015, 02:06
asid61's Avatar
AKA: Anand Rajamani
FRC #1072 (MVRT)
Re: 1710s Robot
If you want to make a can grabber into it, try putting a 1/3 circle cutout on each of your tote grabber arms. If the material is thin enough it should be able to spring enough to allow for both totes and cans, however, your vertical travel is limited enough that I don't know if you can grab onto the can properly.
Unread 01-02-2015, 12:39
Woolly's Avatar
Woolly Woolly is offline
Programming Mentor
AKA: Dillon Woollums
FRC #1806 (S.W.A.T.)
Woolly has a reputation beyond reputeWoolly has a reputation beyond reputeWoolly has a reputation beyond reputeWoolly has a reputation beyond reputeWoolly has a reputation beyond reputeWoolly has a reputation beyond reputeWoolly has a reputation beyond reputeWoolly has a reputation beyond reputeWoolly has a reputation beyond reputeWoolly has a reputation beyond reputeWoolly has a reputation beyond repute
Re: 1710s Robot
I know why you would want to turn that down to half speed for control but that still might be difficult for the driver in the heat of the moment. I'd seriously recomended some kind of string potentiometer or encoder being added so that the forklift can be mostly autonomous. For what you're doing, with a state machine and PID control you could get it down to "Press X to pick up a tote".
Team 1806 Student: 2012-2013 | Mentor: 2013-Present
Unread 01-02-2015, 15:31
AKA: Josh Patterson
Re: 1710s Robot
There is definitely some improvement that could be done here, thats what is great about being this far along by the end of week 4. Thanks for all the advice, stay tuned for updates!
2016-Present FTAA
Unread 01-02-2015, 21:14
ToddF's Avatar
ToddF ToddF is offline
mechanical engineer
AKA: Todd Ferrante
FRC #2363 (Triple Helix)
ToddF has a reputation beyond reputeToddF has a reputation beyond reputeToddF has a reputation beyond reputeToddF has a reputation beyond reputeToddF has a reputation beyond reputeToddF has a reputation beyond reputeToddF has a reputation beyond reputeToddF has a reputation beyond reputeToddF has a reputation beyond reputeToddF has a reputation beyond reputeToddF has a reputation beyond repute
Re: 1710s Robot
Very nice. I like the low CG design.
Todd F.
mentor, FIRST team 2363, Triple Helix
Photo gallery
video channel
Triple Helix mobile
Unread 01-02-2015, 23:10
samfruth's Avatar
Team Role: Driver
Re: 1710s Robot
I have to agree; that driver seems pretty good.
Unread 01-02-2015, 23:12
AKA: Josh Patterson
Re: 1710s Robot
Thanks! That was a major part of our decision making process. At this point we have about 50lbs of weigh left we can add. We'll be doing a much more in-depth analysis of our weigh distribution so we can see if/where we will add weigh.
2016-Present FTAA
Unread 01-02-2015, 23:13
AKA: Josh Patterson
Re: 1710s Robot
Might be tootin' your own horn there a little, huh?
2016-Present FTAA
Unread 02-02-2015, 01:09
221Sarahborg's Avatar
221Sarahborg 221Sarahborg is offline
Alumna Mentor
AKA: Sarah S.
FRC #1810 (Jaguar Robotics)
221Sarahborg is an unknown quantity at this point
Re: 1710s Robot
The low CG and leftover weight is definitely a cool feature next to the simplicity of the method for sure. The intake looks to work really well, too.
KU SADP
1810 - Jaguar Robotics
Alumna Mentor for Electrical & Driving
Team Website & Twitter
Unread 02-02-2015, 03:09
DampRobot's Avatar
Physics Major
AKA: Roger Romani
Re: 1710s Robot
This is a really cool design. Although I've been much less invested in FRC than I have in the past, this design works a lot better and is a lot more simple than anything I came up with after kickoff.
Good work! Now, you just need to test, test, test, iterate, and drive the wheels off the thing.
-Plutarch
Unread 02-02-2015, 12:55
cmrnpizzo14's Avatar
cmrnpizzo14 cmrnpizzo14 is offline
AKA: Cam Pizzo
FRC #3173 (IgKNIGHTers)
cmrnpizzo14 has a reputation beyond reputecmrnpizzo14 has a reputation beyond reputecmrnpizzo14 has a reputation beyond reputecmrnpizzo14 has a reputation beyond reputecmrnpizzo14 has a reputation beyond reputecmrnpizzo14 has a reputation beyond reputecmrnpizzo14 has a reputation beyond reputecmrnpizzo14 has a reputation beyond reputecmrnpizzo14 has a reputation beyond reputecmrnpizzo14 has a reputation beyond reputecmrnpizzo14 has a reputation beyond repute
Re: 1710s Robot
I had a design I was working on earlier this year that was very similar to this. Two of the main problems I was trying to work through were how to pick up Recycling Bins and how to stack on the step for coopertition.
I read that you were trying to come up with something for the bins (best of luck) but I couldn't tell from the video if you could place totes on the step for coopertition. Did you have a solution for this?
FIRST Team 3173 The IgKNIGHTers
"Where should we put the battery?"
