| Thread Tools |
Rating:
Display Modes |
#31
Re: Help Calculating time to recharge air tanks
My assumption is isentropic compression, but I obviously have a mistake in my math somewhere. That's what happens when you take someone who was once pretty good at aerodynamics and thermo and give them a job dealing with spacecraft... |
#32
Is the compressor motor startup current at 100psi specified anywhere? Has anyone measured it with a current probe and a scope? |
#33
I don't believe that the air compressor would be well modeled as an isentropic (reversible) process. Even if the mechanical compression were isentropic, the presence of a heat sink at the compressor output radiating/convecting heat from the compressed air into the environment would make the process irreversible.
#35
-------edit after testing-------- We tested three compressors, using an oscilloscope and current probe to measure (1) initial peak surge current, (2) average current draw during charging, and (3) time to full charge. The test system capacity was 48 cubic inch (3x Clippard AVT 32-16). In each case the duration of the initial surge current was ~0.05 second, rising to its peak in about 0.005 second and decaying exponentially to steady value after that. I have attached a typical oscilloscope plot of the compressor current, 50 seconds full horizontal scale and +/- 40 Ampere full vertical scale. This plot is for the Thomas compressor; other plots are similar in form but differ in their initial peak surge, average current draw, and time to full charge as summarized below. Viair 90C: initial peak surge 18 Ampere, average current draw during charging 12 Ampere, time to full charge 40 seconds. Thomas 405ADC38/12: initial peak surge 32 Ampere, average current draw during charging 10 Ampere, time to full charge 36 seconds. Viair 250C-IG: initial peak surge 40 Ampere, average current draw during charging 9 Ampere, time to full charge 33 seconds. Last edited by Richard Wallace : 02-02-2015 at 22:23. Reason: data |
#37
We've run similar testing and found a wide variation sometimes between compressors of identical models.
For instance, a ViAir 90c that pulled ~6amps and a Thomas that pulled under 10amps while another Thomas pulled ~12 amps. I'd put the Thomas variations down to age and abuse, but I was surprised to see your ViAir 90C pulling so many more amps than some of ours. |
#39
How was the test system controlled? I'm curious what difference (if any) we would see controlling the compressor via a spike versus the new PCM. I'm particularly interested in the surge current for the PCM... Can we measure it both between the PCM and the compressor, and between the PCM and the PDP? The results of such a test may impact whether teams hook their PCM up through the dedicated port with a fuse, or go through a WAGO and a circuit breaker.
#40
My test results above were made using the highly illegal method of series connecting a pressure switch to the compressor -- the opposite of soft-starting! Can someone try the tests Jon suggests using the PCM? We have already returned our beta hardware, and it may be a couple of days before we are ready to test this on our 2015 robot. |
#41
Yes, we started with the tanks empty. I was looking mostly at peak surge current with the 'scope. A stopwatch would suffice to measure refill time, and that should be much shorter than the 0-120 fill times reported above.
Also, I would expect bigger differences in the compressor comparisons for 100-120 refill times, based on their published flow curves. BTW, the peak surge transient (50 msec) we observed would not trip a breaker or blow a fuse. Last edited by Richard Wallace : 03-02-2015 at 11:24. |
#43
Can anyone with a better understanding correlate the readings posted in this thread with the compressor breaker rule we've all been following for years? |
#44
When recharging from ~100 to ~120 PSI, the compressor must start against load. As Mr. V pointed out above, this case is much more pertinent to actual FRC operation than the tests I reported earlier. The initial peak surge current observed using Viair compressors is relatively short duration (<0.1 sec), but the Thomas compressor's initial peak surge current is much longer duration (~0.5 sec). Comparing the Thomas surge against typical automotive fuse curves suggests an explanation for the "conventional wisdom" Jon mentioned above. The Thomas compressor has much less margin against blowing a 20A fuse during surge, and historically that is the compressor on which our FRC "conventional wisdom" is based. Last edited by Richard Wallace : 04-02-2015 at 12:54. |
#45
What people need to keep in mind is that a fuse and the type of circuit breakers that we use are thermal devices. When they reach a certain temp they will open. With a large overload it will open almost instantaneously. With a slight overload it will open but in a longer period. With intermittent medium overloads it can eventual heat to the point where it opens. So the old Thomas compressor if it starts multiple times during a match could certainly eventually heat up the fuse to the point it opens. I'm not sure why they choose the ATM form factor instead of the ATO/ATC form factor as used for the 20/30 amp circuits on the PDP, PDB and Spike. The ATM is not that much smaller than the ATO/ATC. |
