Go to Post I saw a big opening in the bees section and asked if we could sit for this match and was told we were welcome to sit there. Your team made space for about 15 of my team members that came with me. - Debbie [more]
Unread 02-02-2015, 05:21
GuyM142's Avatar
GuyM142 GuyM142 is offline
AKA: Guy
FRC #3339 (BumbleBee)
GuyM142 is just really niceGuyM142 is just really niceGuyM142 is just really niceGuyM142 is just really niceGuyM142 is just really nice
How to calculate max rpm for an encoder?
I would like to calc the max rpm for AS5030-AB-2.0 rotary encoder using the RoboRIO.
How can I calculate it?
Is it a good sensor for measuring chassis wheel velocity?
Thanks!
2016-2017 - Programming Mentor
Curie Sub-Division Champions with 694, 379 & 1511
2015 - Team Captain & Head of Programming Crew
Carson Sub-Division Champions with 1325, 20 & 1711
First ever Israeli team on Einstein
2014 - Team Captain & Head of Programming Crew
2013 - Head of Programming Crew
2012 - Member of Programming Crew
Unread 02-02-2015, 08:49
anthonyttu anthonyttu is offline
Texas Instruments Engineer
AKA: Master Chief
FRC #5417 (Eagle Robotics)
anthonyttu has a spectacular aura aboutanthonyttu has a spectacular aura about
Re: How to calculate max rpm for an encoder?
To calculate the max RPM for a sensor you should consult the manual.
To answer your question of how to calculate this you will take the sampling time at the max sampling rate and divide that by the number of poles on the sensor. This would give you a max RPM Then make sure there is no data transfer limit to the rest of the system or data read rate limits anywhere.
Yes this sensor can measure wheel velocity.
