Go to Post "Building the technology of tomorrow - sometime late tonight!" - dlavery [more]
Unread 06-03-2003, 19:50
petek's Avatar
petek petek is offline
What would Dave do?
AKA: Peter Kieselbach
FRC #3654 (Tech Tigers)
petek has a reputation beyond reputepetek has a reputation beyond reputepetek has a reputation beyond reputepetek has a reputation beyond reputepetek has a reputation beyond reputepetek has a reputation beyond reputepetek has a reputation beyond reputepetek has a reputation beyond reputepetek has a reputation beyond reputepetek has a reputation beyond reputepetek has a reputation beyond repute
Send a message via AIM to petek
Cybersonics 2003 Autodesk Inventor Submission
Cybersonics Technology Team 103 is pleased to announce their submission for the 2003 Autodesk Inventor Award. You can view it here
Cybersonics Inventor Group
Bridgett Jamison
James Bean
Brian Keating
Beckie Kieselbach
Kyle Kotch
William Marek
Mentor: Pete Kieselbach
Unread 06-03-2003, 20:10
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
What a great shifting design. Does it work well?
Unread 06-03-2003, 20:19
Jeff Waegelin's Avatar
El Jefe de 148
AKA: Midwest Refugee
FRC #0148 (Robowranglers)
Looks good! The level of detail is impressive.
Jeff Waegelin
Unread 07-03-2003, 08:16
petek's Avatar
What would Dave do?
It works quite well, actually. Using chain drive (instead of gears or belts) makes it tolerant of small misalignments which lets us use the robot frame to locate the components. That saves weight over a self-contained transmission assembly.
Shifting is very positive. and using a single air cylinder and linked clutches makes sure both transmissions are in the same gear.
We built a speed sensor circuit to give more positive speed control and allow us to go to automatic shifting, but ran out of time and weight to put it on the robot. Something to add next year.
Unread 07-03-2003, 08:18
petek's Avatar
What would Dave do?
Thanks! Our Inventor group really flogged themselves to put this together and will be happy to hear that.
Unread 07-03-2003, 11:46
Did you make that disk withy the pins or buy it? If it was bought, where did it come from? Also, it is shift on the fly right?
Automatic is cool but I would stick with manual so I could have the choice between speed and power right at my fingertips if I was driving.
Unread 07-03-2003, 12:11
petek's Avatar
What would Dave do?
We made the clutch disk and pressed the pins in. Getting that and the hex broach through the center straight was probably the trickiest part of the whole robot.
There are downloads of the Inventor files for these parts here .
The automatic was to have manual override for that very reason. Probably more importantly though, speed sensing would give the controller feedback on actual motor speed, which would have made balancing the drive simpler.
The Science Channel to broadcast FIRST documentary Andy Baker General Forum 49 01-03-2004 14:03
The Autodesk Design Awards 2003 – Call for Entries Brandon Martus 3D Animation and Competition 1 26-12-2003 18:40
Rules on making spare parts fyi DougHogg General Forum 0 02-04-2003 16:18
