Go to Post I just weighed myself and I have gained two pounds since last Saturday. Thats a sign of a good robotics team. - russell [more]
Unread 29-01-2015, 18:02
RobHammann RobHammann is offline
FRC #5143
RobHammann is an unknown quantity at this point
Declaring DoubleSolonoid
I have been trying to get solenoids to work all day, everything I try kicks back an error
grabSolenoid = new DoubleSolenoid(1, 1, 1);
always says "grabSolenoid is not a class"
What is the proper way to declare and run double solenoids? The screensteps isn't helping.
Unread 29-01-2015, 18:59
Jon Stratis's Avatar
Mentor, LRI, MN RPC
FRC #2177 (The Robettes)
Re: Declaring DoubleSolonoid
Try:
DoubleSolenoid grabSolenoid = new DoubleSolenoid(1, 1, 1);
2016: Lake Superior WFFA
Unread 02-02-2015, 10:48
FRC #5143
Originally Posted by Jon Stratis View Post
Try:
Could not convert '(operator new(104u), (<statement>, ((DoubleSolenoid*) <anonymous>)))' from' 'DoubleSolenoid*' to 'DoubleSolenoid'
Unread 02-02-2015, 11:59
GeeTwo's Avatar
GeeTwo GeeTwo is online now
Technical Director
AKA: Gus Michel II
FRC #3946 (Tiger Robotics)
Oh, yeah, C++ forum...try:
DoubleSolenoid *grabSolenoid = new DoubleSolenoid(1, 1, 1);
Unread 02-02-2015, 12:13
Mentor, LRI, MN RPC
Oops, my bad... The syntax is almost identical between java and c++, expert for that annoying *. I really hate dealing with punters in c++!
They issue you were having was that you hadn't declared your variable before assuming it, so the compiler didn't know what "grabSolenoid" was. By adding the class in front, you're telling the compiler what that is.
Unread 02-02-2015, 12:27
one_each one_each is offline
FRC #4057 (KB Bots)
one_each is an unknown quantity at this point
Here is a bit of explenation.
The bolded parts are the important notes. Note the asterisk (or 'star') in the from and also note that it is missing in the to.
The new operator creates a new version of the class (DoubleSolenoid here) and returns a pointer to it. The asterisk (or 'star') indicates changes the type of grabSolenoid to a "pointer to DoubleSolenoid", thus making the types on both sides the same.
Pointers are one of the more confusing aspects of C/C++, however they are used everywhere. Remember, the pointer doesn't hold the data, it just points to where it is at. For classes, use the -> operator to access methods and fields from the pointer.
Unread 02-02-2015, 16:03
FRC #5143
Thanks, they do declare now, however...
I really don't understand these pointers, when I try to set the solenoids using something like
grabSolenoid.set(DoubleSolenoid::kForward);
it says "request for member 'set' in '(((Robot*)this))->Robot::grabSolenoid', which is of pointer type 'DoubleSolenoid' (maybe you meant to use '->' ?)"
where do I put the ->?
Unread 02-02-2015, 16:14
Steve Warner Steve Warner is offline
Controls / Programming
FRC #0234 (Cyber Blue)
Steve Warner is an unknown quantity at this point
Try grabSolenoid->Set(DoubleSolenoid::kForward);
Unread 02-02-2015, 16:20
Originally Posted by RobHammann View Post
...using something like
You have declared grabSolenoid as a pointer to a double solenoid object. The member functions like Set() only work on an actual object. You need to dereference the pointer before you can call the function. The '->' is a small bit of syntax convenience that lets you dereference the pointer and do the equivalent of a '.' at the same time.
Just replace the '.' with '->' between the variable name and the function name.
Unread 02-02-2015, 17:08
GeeTwo's Avatar
Technical Director
AKA: Gus Michel II
Yes. obj_ptr->elt is equivalent to (*obj_ptr).elt . That is, look up the actual field or method within the object that obj_ptr points to.
Unread 02-02-2015, 18:23
Once you get the syntax correct, you'll want to make sure you're allocating unique channels, as you'll likely get a runtime error as written.
Unread 04-02-2015, 15:46
FRC #5143
Well it seems to have worked, I cant test it yet on actual solenoids, but it builds and deploys just fine
