Go to Post Now I'm off to see the wizard, the wonderful wizard of Cogs. - Matt Krass [more]
Unread 26-01-2015, 11:22
RossMN RossMN is offline
FRC #4229
RossMN is an unknown quantity at this point
Lack of Dart Linear Actuator Availability
I think these were a popular design choice based on the Robot In 3 Days videos, but it appears there is no availability, and there will be virtually none. AndyMark informed me the expect "tens" of them late this week, and there will be no more this season. I was wondering if teams had found good replacements out there.
Unread 26-01-2015, 14:15
Zyrano Zyrano is offline
AKA: Alvin
FRC #1967
Zyrano is a splendid one to beholdZyrano is a splendid one to beholdZyrano is a splendid one to beholdZyrano is a splendid one to beholdZyrano is a splendid one to beholdZyrano is a splendid one to behold
Send a message via AIM to Zyrano
Re: Lack of Dart Linear Actuator Availability
So Linear acturators are out there, for example, summitracing sells some, maybe you try to adapt one of those to drive off the cim?
W.R.R.F. Board member, 2007-??
Mentor, 2007-??, NDSJ Robotics FRC Team 1967
Mentor, 2013-15 Evasive Robotics FTC Team 6223
Supporter, 2006-11, Bulldogs Robotics FRC Team 581
Supporter, 2007-??, Pioneer HS Robotics FRC Team 668
Supporter, 2011-??, Dark Matter FRC Team 2643
Student, 1999- GRT FRC Team 192
Unread 26-01-2015, 15:29
tolefanjh tolefanjh is offline
FRC #1585
tolefanjh is an unknown quantity at this point
Our team purchased two 12" Linear Actuators off Ebay, total cost was under $100. With a little thought and design we were able to remove the stock motor and make an adapter plate to mount a CIM and gears to them. Basically removed the original motor and gears and made our own plate to hold a CIM and belt drive system to them.
It can be done, though it isn't off the shelf. In the long run it was much cheaper than going with the Dart models, though those are off the shelf.
Chris.
Unread 26-01-2015, 17:11
FRC #4229
Thanks for the input. So are the stroke speeds pretty much irrelevant since the motor is being replaced by a CIM motor?
Unread 26-01-2015, 19:23
AKA: Alvin
FRC #1967
yup, will depend on the cim loaded speed (if you are using a cim) and gear ratio.
Unread 26-01-2015, 22:55
Nebster's Avatar
Nebster Nebster is offline
AKA: Ben Kishter
FRC #1306 (BadgerBOTS)
Nebster is an unknown quantity at this point
May I ask what kind of linear actuator you purchased that has enough room to mount a cim and is customizable enough to do so? Thanks.
Unread 29-01-2015, 17:44
Mr. B's Avatar
Mr. B Mr. B is offline
FRC #5122 (RobOTies)
Mr. B is an unknown quantity at this point
We found a nook linear actuator from Bearing Specialty for $100 that has a 14" travel.
They have 70 in stock. weight 15.5 LBS. with motor. Gear bore is same dia as cim except no key-just a flat. Mount is similar. We are using a belt sander to make flat on the motor shaft. If your interested call 1-800-427-0990 during the day. I can post pictures this weekend if there is real interest.
Unread 02-02-2015, 13:55
Gustaf16 Gustaf16 is offline
FRC #4229
Gustaf16 is an unknown quantity at this point
We found a good equivalent to them at
http://www.progressiveautomations.co...4sec-p-35.aspx
