Go to Post Like a moth to a flame, true FIRSTers are attracted by the Victor instead of the Banner. - Rich Wong [more]
Unread 02-02-2015, 14:09
Re: Inverting Axis
Originally Posted by GeeTwo View Post
For an example where the simpler code is not easier to read:
Logically, you want to do a conditional:
if (c is between a and b, and you don't know whether a is larger or smaller than b) then...
Human simpler (use this!):
if ((a<b) && (b<c) || (a>b) && (b>c)) then..
Probably machine quicker, but don't use:
if ((a-b)*(b-c) > 0) then..
Either your code is wrong, or your prose description is.
I guess neither is simpler.
Unread 02-02-2015, 16:01
GeeTwo's Avatar
GeeTwo GeeTwo is online now
Technical Director
AKA: Gus Michel II
FRC #3946 (Tiger Robotics)
Re: Inverting Axis
I swapped b and c between the two. Let's correct the prose. I meant to say that b was between a and c, and you didn't know whether a or c were larger.
Unread 03-02-2015, 16:44
2386programming 2386programming is offline
FRC #2386 (Trojans)
2386programming is an unknown quantity at this point
Re: Inverting Axis
 double strafe = mainStick.getRawAxis(3);
         double forward = mainStick.getRawAxis(1);
         double rotation = mainStick.getRawAxis(2);
//mecanum algotrithms
        double mFL = strafe + forward + rotation;
        double mFR = strafe + forward - rotation;
        double mRL = strafe - forward + rotation;
        double mRR = strafe - forward - rotation;
        FL.set(mFL);
        FR.set(mFR);
        RL.set(mRL);
        RR.set(mRR);
This is my code for regular driving for mecanum but I feel that if I inverted the motot not everything else would be the same.
Unread 03-02-2015, 17:31
Re: Inverting Axis
Originally Posted by 2386programming View Post
This is my code for regular driving for mecanum but I feel that if I inverted the motor not everything else would be the same.
The correct inverse kinematics for mecanum is:
double mFL = forward - strafeRight  - rotateClockwise;
double mFR = forward + strafeRight  + rotateClockwise;
double mRL = forward - strafeRight  + rotateClockwise;
double mRR = forward + strafeRight  - rotateClockwise;
If the above doesn't work, it's better to do the necessary motor inverting/swapping to make it work, rather than changing the signs of the kinematics.
