Go to Post I'm down with banning the Chicken Dance (and take the Macerena with you when you go)! - Koko Ed [more]
Thread Tools Rating: Thread Rating: 11 votes, 5.00 average. Display Modes
Unread 02-02-2015, 14:27
Bryan Herbst's Avatar
Bryan Herbst Bryan Herbst is offline
AKA: Bryan
FRC #2052 (KnightKrawler)
Bryan Herbst has a reputation beyond reputeBryan Herbst has a reputation beyond reputeBryan Herbst has a reputation beyond reputeBryan Herbst has a reputation beyond reputeBryan Herbst has a reputation beyond reputeBryan Herbst has a reputation beyond reputeBryan Herbst has a reputation beyond reputeBryan Herbst has a reputation beyond reputeBryan Herbst has a reputation beyond reputeBryan Herbst has a reputation beyond reputeBryan Herbst has a reputation beyond repute
Re: WiFi at a week zero event
Originally Posted by emileh3467 View Post
roborio-####.local and only uses a static IP as a fallback? The routers are configured to assign the RoboRIO a DHCP address (at home use) which I believe can vary should you be using other ethernet devices, such as Axis cameras.
I know thats how we configure them for home use but the competition bridge config may change to set Static IPs. Hopefully FIRST releases some information & if they did we should take a look at the way the FMS connects to the robots.
For real competitions this year the RoboRIO and Drivers Stations will still be using mDNS and getting IPs via DHCP.
Since week zero events will be using last year's FMS (or a third party FMS such as Cheesy Arena), you will need to go into the RoboRIO's settings and set it to a static IP of 10.xx.yy.2, and make sure the radio isn't trying to serve out IPs via DHCP.
Similarly, you'll want to make sure everyone has their driver station configured for the correct IP (10.xx.yy.5).
Team 2052- Knightkrawler
Mentor and volunteer
