Go to Post "Oh, the farmer and the cowhand can be friends, la la la..." - Andy Baker [more]
Unread 02-02-2015, 14:18
Pike3543's Avatar
Pike3543 Pike3543 is offline
Coder
AKA: Connor
FRC #3543 (C4 Robotics)
Pike3543 is an unknown quantity at this point
How do I use the AS5304 sensor?
I am trying to find out how to use the AS5304 sensor and how to get a signal out of it. I'll like to know how to wire it and to get a signal.
Unread 02-02-2015, 14:34
Dartmouth 2020
AKA: lopsided98
FRC #2084 (Robots by the C)
Re: How do I use the AS5304 sensor?
The AD5304 is a magnetic linear encoder, which requires a magnetic strip to work. Assuming you have the magnetic strip, you then place the sensor <1.0mm away from the strip and slide it along the strip. This produces quadrature pulses which can be read using the Encoder class (or VI) in WPILib.
As for wiring, connect the 5V supply and ground to the corresponding pins on the roboRIO, and the A and B channels to two digital inputs. The channel numbers of the digital inputs are what should be supplied to the Encoder constructor/open VI.
Unread 02-02-2015, 14:56
Do you have a bare AS5304 chip, or are you using the adapter board that was supplied for FRC teams in the 2011 Kit of Parts?
If it's the AS5304-AB-2.0 board, with JP1 labeled "Ind AO B A GND 5V", then connect it exactly the way you would connect a quadrature encoder. Because that's exactly what it is. +5 and GND go to the +5 and GND pins of a DIO port on the roboRIO, A goes to the SIG pin, and B goes to the SIG pin of a second DIO port.
http://www.usfirst.org/uploadedFiles...r%20Manual.pdf
Unread 02-02-2015, 15:00
Pike3543's Avatar
Coder
AKA: Connor
Ok thanks. I'm starting to wire it now. How do I get a signal from the Rio. Is their any additional code or anything like that for it to work. Or do I plug it in and it works.
Unread 02-02-2015, 17:11
GeeTwo's Avatar
GeeTwo GeeTwo is offline
Technical Director
AKA: Gus Michel II
FRC #3946 (Tiger Robotics)
Note - programming info is followed up in another thread.
