Go to Post Defense is not at all anti-GP. - Wetzel [more]
Unread 02-02-2015, 17:18
icq10 icq10 is offline
icq10 is an unknown quantity at this point
Dashboard Camera Vision Processing Issues
My situation is very complicated so I try to make it as easy as possible.
We have a camera on our robot and want to have it on our dashboard once with the real image and once with a vision processing filter.
So we created a vision.vi and tried to split the camera input in the dashboard main.vi to the 2 camera image displays.
1.The camera image without vision processing works perfect, but the 2nd image shows nothing.
2. The Vision.Vi is not the issue, we created a separate vi without FRC dashboard and there the camera image gets filtered and displayed perfectly.
So I am assuming that there is an issue with the dashboard input or output of the vision, but I do not know where. I include images of the dashboard main.vi and the vision.vi
Please help me!
ID:	18097  Click image for larger version
Unread 02-02-2015, 17:30
Re: Dashboard Camera Vision Processing Issues
The second image shows "nothing", meaning completely black? You're probably trying to view a threshholded binary image (consisting of 0 and 1 pixels) in an indicator that has a color palette where 0 and 1 are almost indistinguishably dark.
Change the properties of the indicator to have a binary palette instead.
Unread 02-02-2015, 17:37
No, it does not even show black. It is just the area of the camera, with the slightly lighter gray in the background. I am pretty sure that nothing even arrives to the dashboard.
Unread 02-02-2015, 17:45
Your vision.vi is broken, as shown by the fractured "run" arrow. Click on the arrow and it will present a list of errors that you need to address.
Unread 02-02-2015, 17:59
Changed the Display Palette on the Dashboard Main.Vi to Binary as you described it before. Works perfect! Thank you very much!
