Go to Post I do this stuff because...well first inspired me to become me. I now understand who i am better and what i want to do. - Marygrace [more]
Unread 02-02-2015, 18:25
Michael U Michael U is offline
Programmer
FRC #2980
Michael U is an unknown quantity at this point
Re: Serial Open Modifications for Nav6
Yes, we used a USB to serial connector because:
  1. Kauaui Labs (maker of nav6) recommends it
  2. We would need to make a custom connector for the roboRIO (we have never had success with custom connectors)
Unread 02-02-2015, 19:38
dougwilliams's Avatar
dougwilliams dougwilliams is offline
Engineer - Controls, Electronics
FRC #2053 (TigerTronics)
dougwilliams is on a distinguished road
Our team uses the Nav6 (but with C++).
We do not use a USB adapter - less electronics and cables flopping around inside the robot. And less protocol overhead of dealing with USB vs usually a simple bit engine inside a processor for RS232 (amount of overhead for USB could be irrelevant - I did not do any involved analysis).
I didn't want a massive DB9 cable either, so we chopped a PWM cable down to 3 inches and soldered directly to the backside of the DB9 connector on the Nav6. (Note to reader - that would usually void a warranty). I considered removing the DB9 entirely, but figured it wasn't hurting anything or getting in the way, and could be useful later).
One of the students also designed and then 3D printed a RoboRio to Nav6 adapter plate. The Nav6 is now bolted in the middle of the RoboRio with just a tiny 3wire, 3 inch cable to the RS232 port.
It works and is very sleek. We can share details or files if anyone is interested.
