Go to Post While money can create fancy-looking robots, it does not always create game-winning ideas. - Karibou [more]
Unread 02-02-2015, 18:50
pluto7443 pluto7443 is offline
FRC #4917
pluto7443 is an unknown quantity at this point
Unhappy Two Commands Co-Existing depsite Requires()
So, we have a problem with using two commands that both require our IntakeSub subsystem. One is the default command, used for manual control of the intake with a joystick, and the other is a command which should override the default. The manual control works fine, however, when the command is called (by pressing a button), the command starts to run, not interrupting the default command. Both commands use Requires(mIntakeSub) in their constructor - why doesn't the button command interrupt the default?
Unread 02-02-2015, 20:48
afiolmahon afiolmahon is offline
FRC #1218
afiolmahon is an unknown quantity at this point
Re: Two Commands Co-Existing depsite Requires()
Are you able to post the code for both commands?
Unread 02-02-2015, 21:52
JohnSmooth42 JohnSmooth42 is offline
Is writing code
FRC #0375 (The Robotic Plague)
JohnSmooth42 is an unknown quantity at this point
Have you made sure you have code in the IsInterrupted() function of the command? I decided to try out the command based framework two days ago(ported all the SampleRobot code in 10 hours ) and we had a similar problem, which was fixed by making sure the commands actually ended when we wanted them to.
Unread 02-02-2015, 22:43
TFleig78's Avatar
TFleig78 TFleig78 is offline
AKA: Tyler
FRC #0078 (Air Strike)
TFleig78 will become famous soon enoughTFleig78 will become famous soon enough
How do you know it's not interrupting the default command? Do you have code in the interrupted function?
Unread 02-02-2015, 22:46
GeeTwo's Avatar
GeeTwo GeeTwo is offline
Technical Director
AKA: Gus Michel II
FRC #3946 (Tiger Robotics)
This may sound like "is the computer plugged in", but is this actually running under the command based robot model?
Unread 09-02-2015, 19:46
FRC #4917
The solution was that we had OI initialized before some other subsystems, which was causing strange behaviour. ALWAYS INIT OI LAST!
