Go to Post "So Ken Patton, Paul Copioli, and John V-Neun walk into a bar..." - JVN [more]
Unread 31-01-2015, 13:48
RoboBucs RoboBucs is offline
FRC #5005
RoboBucs is an unknown quantity at this point
Toggle Between Two Cameras in Vision Processing
Hello, I am trying to make it to where I can toggle between two cameras in vision processing, and I tried to toggle between the cameras with a button on the joystick, but it did not work. How would I fix this?
Unread 31-01-2015, 21:50
adciv adciv is offline
One Eyed Man
FRC #0836 (RoboBees)
Re: Toggle Between Two Cameras in Vision Processing
Are you using Axis cameras or USB cameras?
Unread 01-02-2015, 10:25
I'm not saying that this is going to fix everything, but the code is only reading the joystick once, outside the loop.
So move the Get Value inside each loop and at least at that point, you can probe and see that the buttons are working.
Greg McKaskle
Unread 02-02-2015, 16:38
FRC #5005
Ok, I am using USB Cameras, and I will try to place the get values into the loop. Thanks you all!
Unread 02-02-2015, 16:44
One Eyed Man
I'm planning to do this on our robot with USB cameras. My goal is to get the code done by tomorrow evening. If I can get it done, I'll post it.
Unread 02-02-2015, 17:11
FRC #5005
Exclamation Re: Toggle Between Two Cameras in Vision Processing
That would be great! I'm still actually getting no connection between both cameras at the same time. I also tried to put the values into the loops, and there was still no change. But thank you for your idea. This is what it looks like right now:
Unread 02-02-2015, 21:24
As I said, it may not fix all of the issues, but I guarantee that if you do not put the Joystick Get Values inside of each loop, you are only reading them once at the beginning. That is, I assume a part of the bug you are reporting.
Greg McKaskle
Unread 02-02-2015, 22:02
FRC #5005
Greg McKaskle
Do you know anything else we could do to try to fix that? We tried it with the joystick inside with no results.
Unread 02-02-2015, 22:09
When toggling, are you by chance expecting the camera image on the Dashboard to change?
It won't, since the Dashboard forwarding is handled in the Camera IP & Dash vi.
Since you aren't doing anything in the Vision Processing loop, you won't see any effect of your joystick button, even if it weren't stuck at the first and only read.
Unread 03-02-2015, 07:01
I had a bit more time to look at this.
As Mark mentioned, the actual code for sending USB camera images to the DB is inside of the IP & Dash VI.
What type of cameras do you have? The current WPI VIs are setup to handle one USB camera forwarded to the DB. They don't have a ready mechanism to swap cameras, but it wouldn't be hard to add it.
If one of the cameras were IP, it would be even simpler.
So, what types of cameras do you have?
Greg McKaskle
Unread 03-02-2015, 08:34
GrantCrowder's Avatar
GrantCrowder GrantCrowder is offline
GrantCrowder is an unknown quantity at this point
Greg, I'm assuming that this is a boolean function, so I will do some testing today with it. I'm also going to work with the dash vi today, so I will start working with it. Thanks
Unread 03-02-2015, 14:13
FRC #5005
Greg McKaskle
They are both usb cameras, I won't know model numbers until I get to the shop today.
Unread 03-02-2015, 16:21
FRC #5005
Greg McKaskle
The webcams are Microsoft livecam hd 3000
Unread 03-02-2015, 19:11
One Eyed Man
Ok, I hacked this together in about 90 minutes and verified it works with two of our HD-3000 cams. Everything is located in the "Vision Processing.vi". It uses the "DB/Button 1" switch on the dashboard. True will give you one camera, false the other. It only runs in "HW Mode". There is a small switching delay.
*Edit* now with file.
Unread 03-02-2015, 20:05
FRC #5005
Thank you so very much!!!
