Go to Post Some things in life are far more important than Robotics. - IMDWalrus [more]
Unread 30-01-2015, 20:20
team-4480's Avatar
team-4480 team-4480 is offline
Debug? What's that?
FRC #4480
team-4480 will become famous soon enoughteam-4480 will become famous soon enough
RoboRIO suddenly doesn't work?
Hi! We just hit a major bump in the road. Our roboRIO that was programmed in Python(RobotPy), suddenly does not drive. Our Jaguars hold a solid yellow light which means that it should work. When we try to use any of our joysticks, the lights don't change color. Using the same code before, the robot worked and there was no problems. Any help or ideas will be greatly appreciated!!! Code if it matters: http://pastebin.com/i7cW3eXD.
Unread 30-01-2015, 21:55
virtuald's Avatar
virtuald virtuald is offline
RobotPy Guy
AKA: Dustin Spicuzza
Re: RoboRIO suddenly doesn't work?
Presumably you've rebooted, etc. Does it switch into teleoperated/autonomous/etc mode? Does it show no code? More details?
Unread 30-01-2015, 22:02
team-4480's Avatar
Debug? What's that?
FRC #4480
Yes we rebooted, so it switches to teleop mode and it does detect my code. I enable the robot, but the speed controllers don't change color when I press buttons and joysticks. Thanks!
Unread 30-01-2015, 22:56
x86_4819's Avatar
x86_4819 x86_4819 is offline
computer-whisperer
AKA: Christian Balcom
FRC #4819 (Flat Mountain Mechanics)
x86_4819 is on a distinguished road
Make sure that your joysticks are configured correctly in the driver station. I have found that the stick order can get easily shuffled around when plugging and unplugging joysticks.
My Github Repositories
Unread 03-02-2015, 01:27
Fauge7 Fauge7 is offline
Head programmer
FRC #3019 (firebird robotics)
Fauge7 is a name known to allFauge7 is a name known to allFauge7 is a name known to allFauge7 is a name known to allFauge7 is a name known to allFauge7 is a name known to all
also make sure to check the output on the riolog, code can crash causing it to not run and not operate.
Unread 03-02-2015, 18:06
team-4480's Avatar
Debug? What's that?
FRC #4480
Just for those who are wondering, we got our roboRIO to work! All we did was hit the reset button on the roboRIO a couple times and redeployed. Thanks for all the help!!
