Go to Post Being a part of FIRST is inspirational regardless of what else happens. - Jon Stratis [more]
Unread 02-02-2015, 20:45
Wenry_Hill Wenry_Hill is offline
FRC #2539
Wenry_Hill is a glorious beacon of lightWenry_Hill is a glorious beacon of lightWenry_Hill is a glorious beacon of lightWenry_Hill is a glorious beacon of lightWenry_Hill is a glorious beacon of light
Talon SRX spamming forward and backward constantly
Hello everybody,
So our robot's Talon's are reversing forward and backward during teleOP and Auton. During the Auton program it's set to move forward a single motor at half speed for half a second then stop. What actually happens is 2 motors continually go forward and backward at full speed(I think). We have the Talons in a CAN daisy chain sequence and are using c++ to program it. Any help would be much appreciated.
Unread 02-02-2015, 20:52
Asymons Asymons is offline
FRC #4716 (Purple Raiders)
Team Role: Driver
Asymons is an unknown quantity at this point
Re: Talon SRX spamming forward and backward constantly
Can you post the code you're using to control said motors? (Just to eliminate the possibility of the code being the issue).
Unread 02-02-2015, 22:20
Munchskull's Avatar
Munchskull Munchskull is offline
CAD Designer/ Electrical Consaltant
AKA: Anthony Cardinali
FRC #0997 (Spartan Robotics)
Team Role: CAD
Munchskull is a splendid one to beholdMunchskull is a splendid one to beholdMunchskull is a splendid one to beholdMunchskull is a splendid one to beholdMunchskull is a splendid one to beholdMunchskull is a splendid one to beholdMunchskull is a splendid one to beholdMunchskull is a splendid one to behold
Try calibrating it. That might solve the problem if it is not codes problem.
“In theory, theory and practice are the same. In practice, they are not.” ― Anonymous
Anthony Cardinali
4th year of FRC
Class of 2017
Unread 02-02-2015, 22:57
GeeTwo's Avatar
GeeTwo GeeTwo is offline
Technical Director
AKA: Gus Michel II
FRC #3946 (Tiger Robotics)
My spitball guess is that both Talons have the same CAN address, and one is on the left side of the robot, and the other is on the right side of the robot. When you send the command, both motors respond by rotating in the same direction. However, as the motors are oriented in opposite directions, one of them appears to be going backward.
Unread 02-02-2015, 23:43
Christopher149 Christopher149 is offline
FRC #0857 (Superior Roboworks) FTC 10723 (SnowBots)
Christopher149 has a reputation beyond reputeChristopher149 has a reputation beyond reputeChristopher149 has a reputation beyond reputeChristopher149 has a reputation beyond reputeChristopher149 has a reputation beyond reputeChristopher149 has a reputation beyond reputeChristopher149 has a reputation beyond reputeChristopher149 has a reputation beyond reputeChristopher149 has a reputation beyond reputeChristopher149 has a reputation beyond reputeChristopher149 has a reputation beyond repute
Do you ever explicitly tell the motors to stop moving?
2015-present: FTC 10723 mentor
2012-present: 857 mentor
2008-2011: 857 student
2015: Industrial Design, Excellence in Engineering, District Finalist, Archimedes Division (#6 alliance captain)
2014: Judges Award, District Engineering Inspiration, District Finalist, Galileo Division
Unread 03-02-2015, 07:34
restouffer's Avatar
restouffer restouffer is offline
AKA: Bob Stouffer
FRC #2539 (Krypton Cougars)
restouffer is an unknown quantity at this point
I think Wenry may be in class, so his responses will be a bit delayed. I was at the build last night and helped him with his troubleshooting, so I will take a stab at answering your questions.
@Asymons - I don't have direct access to the code that was being used (it hasn't been pushed to our repo yet), but the final test was really simple. I'll try to replicate it here.
We had a command with the following methods:
void TestTalonCommand::Initialize()
	drivetrain->setMotorSpeed(1, 0.5);
void TestTalonCommand::End()
	drivetrain->setMotorSpeed(1, 0);
The command requires the drivebase subsystem, and it uses the built in timing from Command to run for 0.5 seconds.
The setMotorSpeed method is in our subclass of RobotDrive, and implemented like this:
void Drive::setMotorSpeed(unsigned int motorID, float speed)
	motors[motorID]->Set(speed);
motors is a vector created in the constructor, and each object is instantiated with "new CANTalon(canID);", where there are different CAN IDs for each of our Talon SRXes.
The Talons are in kThrottle or kPercentVbus mode (Both are names for ControlMode 0).
@Munchskull - I was wondering about that, but since the robot uses CAN instead of PWM I didn't think normal calibration applied. At least, I couldn't find anything in the Talon SRX User Guide for calibrating the Talons for CAN. Do you have documentation on how we could do this?
@GeeTwo - All of the Talons have unique IDs in the web interface. They are also all using the latest (1.4) version of the firmware.
@Christopher149 - Yes. This is the part that is exceptionally puzzling. When the move command is sent (either by moving the joystick or by calling Set()) the motors begin moving. However, when the joystick is returned to center or the command ends, the motors do not stop until the robot is disabled.
Thanks to all of you for responding.
Unread 03-02-2015, 14:28
ozrien's Avatar
ozrien ozrien is offline
Omar Zrien
AKA: Omar
PWM Calibration has no effect when controlling Talon SRXs over CAN bus.
It sounds like a programming issue, can you just post it in it's entirety? Or PM me a link and I can run it on my robot.
Unread 03-02-2015, 16:19
FRC #2539
Sorry if this doesn't look pretty i'm new to forms. Also if i should add anything else just let me know please. Thank you for helping
TestTalonCommand.cpp file
#include "TestTalonCommand.h"
TestTalonCommand::TestTalonCommand()
	: TimedCommand("TestTalonCommand", 0.5)
	Requires(drivetrain);
	drivetrain->setMotorSpeed(1,0.5);
	drivetrain->setMotorSpeed(1,0);
TestTalonCommand.h file
#ifndef TEST_TALON_COMMAND_H
#define TEST_TALON_COMMAND_H
#include "../Types/TimedCommand.h"
class TestTalonCommand : public TimedCommand {
public:
	TestTalonCommand();
	void Initialize();
	void End();
#endif
Mecanum.cpp
#include "MecanumDriveTrain.h"
#include "../RobotMap.h"
#if defined(MECANUM_DRIVE)
#include "../Custom/DriveTrain/EncoderDrive.h"
#include <CANTalon.h>
#include <Gyro.h>
#include "../Custom/Netconsole.h"
MecanumDriveTrain::MecanumDriveTrain() : DriveTrain("MecanumDriveTrain")
	frontRightMotor = new CANTalon(RobotMap::DriveBase::frontRightMotorID);
	frontLeftMotor = new CANTalon(RobotMap::DriveBase::frontLeftMotorID);
	backRightMotor = new CANTalon(RobotMap::DriveBase::backRightMotorID);
	backLeftMotor = new CANTalon(RobotMap::DriveBase::backLeftMotorID);
	gyro = new Gyro(RobotMap::DriveBase::gyroPort);
	gyro->SetSensitivity(RobotMap::DriveBase::gyroSensitivity);
	drive = new EncoderDrive(frontLeftMotor, backLeftMotor, frontRightMotor, backRightMotor);
	drive->SetSafetyEnabled(false);
	drive->ignoreEncoders();
	DEBUG_MOTOR(frontLeftMotor);
	DEBUG_MOTOR(frontRightMotor);
	DEBUG_MOTOR(backLeftMotor);
	DEBUG_MOTOR(backRightMotor);
MecanumDriveTrain::~MecanumDriveTrain()
	delete frontLeftMotor;
	delete frontRightMotor;
	delete backLeftMotor;
	delete backRightMotor;
	delete gyro;
void MecanumDriveTrain::move(float xValue, float yValue, float rotate)
	drive->MecanumDrive(xValue, yValue, rotate, gyro->GetAngle());
void MecanumDriveTrain::stop()
	drive->MecanumDrive(0.0, 0.0, 0.0);
void MecanumDriveTrain::setMotorSpeed(RobotMap::CanID motorID, float speed)
{	drive->setMotorSpeed(motorID,speed);
#endif
MecanumDriveTrain.h file
#ifndef MECANUM_DRIVE_TRAIN_H
#define MECANUM_DRIVE_TRAIN_H
#include "DriveTrain.h"
class CANTalon;
class Gyro;
class MecanumDriveTrain: public DriveTrain {
public:
	MecanumDriveTrain();
	virtual ~MecanumDriveTrain();
	void setMotorSpeed(RobotMap::CanID motorID, float speed);
	void move(float xValue, float yValue, float rotateValue);
	virtual void stop();
protected:
	CANTalon* frontLeftMotor;
	CANTalon* frontRightMotor;
	CANTalon* backLeftMotor;
	CANTalon* backRightMotor;
	Gyro* gyro;
#define MOVE_WITH_JOYSTICK\
	move(\
		oi->getAxisValue(logicalAxes::DriveX),\
		oi->getAxisValue(logicalAxes::DriveY),\
		oi->getAxisValue(logicalAxes::DriveRotate)\
#endif
EncoderDrive.h file
#ifndef ENCODER_DRIVE_H
#define ENCODER_DRIVE_H
#include <RobotDrive.h>
#include "../../RobotMap.h"
#include <vector>
class SpeedController;
class CANTalon;
class Encoder;
class RatePIDController;
class PIDSource;
class EncoderDrive : public RobotDrive {
public:
	EncoderDrive(
		SpeedController* leftMotor,
		SpeedController* rightMotor,
		Encoder* leftEncoder,
		Encoder* rightEncoder
	EncoderDrive(
		CANTalon* frontLeftMotor,
		CANTalon* backLeftMotor,
		CANTalon* frontRightMotor,
	virtual void SetLeftRightMotorOutputs(float leftOutput, float rightOutput);
	virtual void MecanumDrive(double x, double y, double rotate, double angle=0.0);
	void setMaxSpeed(float speed);
	void ignoreEncoders();
protected:
	float m_maxSpeed;
	bool m_brokenEncoder;
	std::vector<PIDSource*> sensors;
	std::vector<RatePIDController*> outputs;
	std::vector<SpeedController*> motors;
	std::vector<float> speeds;
	void equalizeMotors();
	void addMotor(PIDSource* sensor, SpeedController* motor);
#endif
EncoderDrive.cpp file
#include "EncoderDrive.h"
#include <cmath>
#include <iterator>
#include <algorithm>
#include <Encoder.h>
#include "RatePIDController.h"
#include "EncoderRatePIDSource.h"
#include "CANTalonRatePIDSource.h"
#include "../Netconsole.h"
EncoderDrive::EncoderDrive(
): RobotDrive(leftMotor, rightMotor),
	m_maxSpeed(RobotMap::DriveBase::maxSpeed),
	m_brokenEncoder(false)
	addMotor(new EncoderRatePIDSource(leftEncoder), leftMotor);
	addMotor(new EncoderRatePIDSource(rightEncoder), rightMotor);
	speeds.resize(motors.size());
): RobotDrive(frontLeftMotor, backLeftMotor, frontRightMotor, backRightMotor),
	addMotor(new CANTalonRatePIDSource(frontLeftMotor), frontLeftMotor);
	addMotor(new CANTalonRatePIDSource(backLeftMotor), backLeftMotor);
	addMotor(new CANTalonRatePIDSource(frontRightMotor), frontRightMotor);
	addMotor(new CANTalonRatePIDSource(backRightMotor), backRightMotor);
void EncoderDrive::setMaxSpeed(float speed)
	m_maxSpeed = speed;
void EncoderDrive::SetLeftRightMotorOutputs(float leftOutput, float rightOutput)
	if (m_brokenEncoder)
		RobotDrive::SetLeftRightMotorOutputs(leftOutput, rightOutput);
		return;
	speeds[0] = leftOutput;
	speeds[1] = -rightOutput; // Should we set this motor inverted?
	equalizeMotors();
void EncoderDrive::MecanumDrive(double x, double y, double rotate, double angle)
		Netconsole::print<double>("X", x);
		Netconsole::print<double>("Y", y);
		Netconsole::print<double>("Rotate", rotate);
		RobotDrive::MecanumDrive_Cartesian(x, -y, rotate, angle);
		return;
	static bool reported = false;
	if (!reported)
		HALReport(
			HALUsageReporting::kResourceType_RobotDrive,
			motors.size(),
			HALUsageReporting::kRobotDrive_MecanumCartesian
		reported = true;
	// Compensate for gyro angle.
	RotateVector(x, y, angle);
	speeds[kFrontLeftMotor] = x + y + rotate;
	speeds[kFrontRightMotor] = -x + y - rotate;
	speeds[kRearLeftMotor] = -x + y + rotate;
	speeds[kRearRightMotor] = x + y - rotate;
	// Normalize joystick values
	float maxSpeed = std::abs(speeds[kFrontLeftMotor]);
	for (int i = 1; i < kMaxNumberOfMotors; i++)
		float currentSpeed = std::abs(speeds[i]);
		if (currentSpeed > maxSpeed)
			maxSpeed = currentSpeed;
	if (maxSpeed > 1.0)
		for (int i=0; i < kMaxNumberOfMotors; i++)
			speeds[i] = speeds[i] / maxSpeed;
	equalizeMotors();
void EncoderDrive::addMotor(PIDSource* sensor, SpeedController* motor)
	sensors.push_back(sensor);
	motors.push_back(motor);
	RatePIDController* output = new RatePIDController(
		RobotMap::DriveBase::P,
		RobotMap::DriveBase::I,
		RobotMap::DriveBase::D,
		1,
		sensor,
		motor
	output->SetInputRange(-m_maxSpeed, m_maxSpeed);
	output->SetPercentTolerance('1');
	output->Enable();
	outputs.push_back(output);
void EncoderDrive::equalizeMotors()
	int motorCount = motors.size();
	float maxInput = 1;
	float currentInput = 0;
	float peggedInput = 0;
	int peggedIndex = -1;
	// If one motor is pegged, don't let the others pass it
	// NOTE: Are there cases where motors could be pegged at different values?
	for (int i=0; i < motorCount; i++)
		currentInput = std::abs(motors[i]->Get());
		if (currentInput > .99)
			peggedInput = std::abs(sensors[i]->PIDGet()) / m_maxSpeed;
			if (peggedInput < maxInput)
				maxInput = peggedInput;
				peggedIndex = i;
	if (peggedIndex != -1)
			if (i == peggedIndex)
				continue;
			if (speeds[i] >= 0)
				speeds[i] = std::min(speeds[i], maxInput);
			else
				speeds[i] = std::max(speeds[i], -maxInput);
		outputs[i]->SetSetpoint(speeds[i] * m_maxSpeed);
	m_safetyHelper->Feed();
void EncoderDrive::ignoreEncoders()
	m_brokenEncoder = true;
void EncoderDrive::setMotorSpeed(RobotMap::CanID motorID, float speed)
Unread 03-02-2015, 17:55
FRC #2539
Also here is the link to our repository https://github.com/FRC2539/command-based/tree/rrush. Thanks all for the help.
Unread 03-02-2015, 18:28
FRC #2539
Arrived at the build site, here's what we're dealing with https://www.youtube.com/watch?v=_ALFjkahQuk. Thanks again for the help.
Unread 03-02-2015, 19:39
FRC #2539
We looked into that but we're using CAN instead of PWM but calibration would only affect PWM. Thanks for the idea though.
Unread 03-02-2015, 19:42
FRC #2539
We looked at the CAN addresses and there all different. Also when we enabled the robot we found that determining which wheels will turn on is never consistent. Thanks for the suggestion though.
Unread 03-02-2015, 19:45
FRC #2539
Yes in our autonomous program it's only set to run for half a second, however that never happens but thanks anyway. See the you-tube video above.
Unread 03-02-2015, 19:46
mandrews281 mandrews281 is offline
FRC #0281
mandrews281 is a splendid one to beholdmandrews281 is a splendid one to beholdmandrews281 is a splendid one to beholdmandrews281 is a splendid one to beholdmandrews281 is a splendid one to beholdmandrews281 is a splendid one to beholdmandrews281 is a splendid one to behold
We are having very similar problems with our drive system. We are running Talon SRX's using CAN and mechanum drive using C++ IterativeRobot. We have some motors not turning and others spin slowly in the wrong direction while other motors are running at full speed. We are also seeing some CAN errors from the PDB not responding on the DriverStation messages.
The Talons all have unique CAN IDs and have had a firmware update (from memory, I think they're running version 1.4). Same with the PDB (I think it's firmware level is 1.37). We are driving the motors using the RobotDrive.
2539: If you figure this out, please post your solution. I was going to try increasing the control period on the CANTalon's, but I'm not confident this will work.
Thanks
Michael Andrews
Team #281 Programming Mentor
Unread 03-02-2015, 20:33
ozrien's Avatar
Omar Zrien
AKA: Omar
There is definitely something wrong with that robot app. Running it on my bot it looks like two things are trying to drive all the Talons, it keeps switching between zero and nonzero values. I'll keep digging...
