Go to Post You have to start at the bottom to get to the top, usually. - Kyle [more]
Unread 03-02-2015, 09:21
Re: Motor Stuttering
I am guessing your code is doing something like this:
if button 1 pressed
  then run motor forward
  else stop motor
endif
if button 2 pressed
  then run motor backward
  else stop motor
endif
Button 2 will work. However, if you press button 1 the motor will run but will immediately be stopped by the button 2 code.
Instead, try this:
if button 1 pressed
endif
if button 2 pressed
endif
if neither button pressed
  then stop motor
endif
You might also want to explicitly deal with both buttons pressed at the same time.
