Go to Post I can't help looking at the new center piece my wife put on the dinning room table and think to myself, "non-functional decoration" - DarrinMunter [more]
Unread 02-02-2015, 13:27
frc_team_4615 frc_team_4615 is offline
FRC #4515
frc_team_4615 is an unknown quantity at this point
Motor Stuttering
Hello all,
We are trying to program one of our motors to move one direction when we press a button and the other direction off of a different button. We're using a Jaguar motor controller right now.
When going one direction operation is normal but the reverse direction stutters. If we reverse the code we get the same results but with opposite directions.
If we use the joystick axis to control this movement both directions are working. We checked that the buttons are at 1 and -1 when pressed.
Things we've tried so far:
Different motor
Different motor controller
Changed which buttons were assigned in the code
Changed which directions were assigned in the code
I tried searching but was having trouble with using the right keywords. Has anyone else had this problem? Is there an easier way to accomplish the same task?
TIA
Unread 02-02-2015, 13:36
AustinH's Avatar
AustinH AustinH is offline
FRC #4918 (The Roboctopi)
AustinH is a splendid one to beholdAustinH is a splendid one to beholdAustinH is a splendid one to beholdAustinH is a splendid one to beholdAustinH is a splendid one to beholdAustinH is a splendid one to behold
Re: Motor Stuttering
Doesn't sound like a hardware problem. When this happened to us on our first lift test, we dug through the code and found conflicting instructions being sent to the motor controller when various buttons were pushed. Can you publish some of your code?
3826: 2013 Seattle Regional Industrial Design Award & Semi-Finalists
4918: 2014 PNW Glacier Peak District Event Rookie Inspiration Award & Quarter-Finalists, 2014 PNW Mount Vernon District Event Highest Rookie Seed Award, Rookie All Star & Semi-Finalists, 2015 PNW West Valley District Event Engineering Excellence Award & Semi-Finalists, 2015 PNW Mount Vernon District Event Semi-Finalists
Visit us on the web at www.team4918.org
Unread 02-02-2015, 13:37
notmattlythgoe's Avatar
Flywheel Police
AKA: Matthew Lythgoe
FRC #2363 (Triple Helix)
What are you programming in? Can you post your code?
Unread 02-02-2015, 13:42
AllenGregoryIV's Avatar
Engineering Coach
AKA: Allen "JAG" Gregory
FRC #3847 (Spectrum)
This was my first thought as well. It sounds like part of your code is sending 0 and then a different part is sending 1. Is the stop command from the first button always executing when it's not pressed? That would be my blind guess.
Unread 03-02-2015, 07:00
jgrindle's Avatar
jgrindle jgrindle is offline
Losing Sleep
AKA: John Grindle
FRC #5122 (RobOTies)
Rookie Year: 2015
jgrindle will become famous soon enough
Would you be able to post your riolog? if you're working in java or c. Also posting your code to github would be helpful, we've had a similar problem. If it's on github, it makes for other teams to help debug a little easier.
FRC 2015 Season: Programmer, Electrical, PIDTuner, Safety Captain
FRC 2015 Off-Season: Programmer, CAD Designer, Driver, Drive Team Coach, Electrical, Mechanical, PIDTuner
Unread 03-02-2015, 09:21
I am guessing your code is doing something like this:
if button 1 pressed
  then run motor forward
  else stop motor
endif
if button 2 pressed
  then run motor backward
  else stop motor
endif
Button 2 will work. However, if you press button 1 the motor will run but will immediately be stopped by the button 2 code.
Instead, try this:
if button 1 pressed
endif
if button 2 pressed
endif
if neither button pressed
  then stop motor
endif
You might also want to explicitly deal with both buttons pressed at the same time.
