Go to Post Education doesn't have anything to do with how much money a person can make. Experience, Perseverence, and Character do. - Jnadke [more]
Thread Tools Rating: Thread Rating: 39 votes, 5.00 average. Display Modes
  #31   Spotlight this post!
Unread 03-02-2015, 11:18
brk brk is offline
FRC #0180
brk is an unknown quantity at this point
Re: OpenCV for RoboRio - Release
To encode the JPEG, i have:
unsigned int SPAMVision::_encodeJpeg(std::vector<uchar> & dst, cv::Mat src, int quality)
std::vector<int> param = std::vector<int>(2);
param[0] = CV_IMWRITE_JPEG_QUALITY;
param[1] = quality;
cv::imencode(".jpg", src, dst, param);
return dst.size();
And I use this in something very similar to the CameraServer class.
  #32   Spotlight this post!
Unread 03-02-2015, 11:40
brk brk is offline
FRC #0180
I have a new problem...
I'm trying to do this on a beaglebone black.
I thought it should work out of the box, but...
when I run an executable built in eclipse, I get:
error while loading shared libraries: libstdc++.so.6.0.20: cannot open shared object file: No such file or directory
ldd shows libstdc++.so.6 isn't found, as well as some others.
In fact, these are the missing ones (from ldd)
libffi.so.6 => not found
libstdc++.so.6 => not found
libstdc++.so.6.0.20 => not found
libz.so.1 => not found
This will be a problem in that the beaglebone only has libstdc++.so.6.0.17.
Does that mean I need to recompile opencv for this to remove that dependency?
  #33   Spotlight this post!
Unread 04-02-2015, 18:03
Sparkyshires Sparkyshires is offline
AKA: Michael Shires
FRC #0384 (Sparky)
Sparkyshires is an unknown quantity at this point
hello!
Looks like an awesome resource. I'm having an issue though. When I try and compile it it gives errors on all the includes, even string and anything else from the c std library. Do you have any solutions for this?
Thanks again!
"Measure with a micrometer, mark with chalk, cut with an axe."
  #34   Spotlight this post!
Unread 04-02-2015, 18:39
mikhail's Avatar
mikhail mikhail is offline
AKA: Mentor of The Software ERRORs
FRC #3130 (ERRORS)
mikhail is an unknown quantity at this point
Originally Posted by Sparkyshires View Post
hello!
Thanks again!
Yes, there is always a solution. Remove or change the line #8 in WPILib.h which defines "REAL" (#define REAL) to something else, e.g. "#define REAL_ROBOT"
Details: http://www.chiefdelphi.com/forums/sh...8&postcount=18
  #35   Spotlight this post!
Unread 04-02-2015, 19:31
jreneew2's Avatar
jreneew2 jreneew2 is offline
Alumni of Team 2053 Tigertronics
AKA: Drew Williams
FRC #2053 (TigerTronics)
jreneew2 has a spectacular aura aboutjreneew2 has a spectacular aura aboutjreneew2 has a spectacular aura about
Hello there! We are up to the point where we can grab image data from the camera and process it using OpenCV. However, we can't figure out how to get that jpeg data on the smartdashboard via CameraServer.
Here is what we have:
	std::string videoStreamAddress = "http://169.254.149.22/mjpg/video.mjpg";
	Mat frame;
	VideoCapture vidcap;
	vidcap.open(videoStreamAddress);
	vidcap >> frame;
	vector<int> param = vector<int>(2);
	param[1] = 80;
	vector<uchar> img_data;
	imencode(".jpg", frame, img_data, param);
        // This is where we're stuck :)
	RobotMap::cam_server->SetImage();
SetImage seems to take a Image object. We cannot find any real documentation on how to use this object. Any help would be most appreciated.
Thanks,
Team 2053
  #36   Spotlight this post!
Unread 04-02-2015, 19:37
Dartmouth 2020
AKA: lopsided98
FRC #2084 (Robots by the C)
The CameraServer is designed to work with the the NI Vision libraries and I don't know how to make it work with OpenCV. I wrote an OpenCV mjpg server a while ago (not for the roboRIO), that you might be able to make work. It requires Boost, which might be difficult to get on the roboRIO. Maybe it will help you with something though.
