Go to Post Win, Lose or Tie, but do it in a way that FIRSTers will be talking about for years to come! - Bill Moore [more]
Unread 02-03-2015, 11:49 AM
Re: roboRIO Command Based Problems
Originally Posted by King Nerd III View Post
Long story short the lesson here is when in doubt reformat until it works!
I doubt that is good advice. Unless there is something physically wrong with the system, reimaging a roboRIO a bunch of times can't do anything that reimaging it once will do. The class of problems that can be solved with a single reimage step is very small, and they are very rare.
Instead of going for the reimaging/reformatting voodoo, you should troubleshoot your original problem using the tools suggested here by the people trying to help you.
Unread 02-03-2015, 11:52 AM
King Nerd III's Avatar
King Nerd III King Nerd III is offline
Chief Programmer/Head of Autonomous
AKA: Isaac
FRC #1410 (The Kraken)
King Nerd III is an unknown quantity at this point
It's usually all that works for us. The troubleshooting will help with minor things, but when the robot is turned off mid format? Nothing else would help. Heck, the troubleshooting tools wouldn't even detect the roboRIO.
Unread 02-03-2015, 12:27 PM
solopilot solopilot is offline
FRC #0293
solopilot is a name known to allsolopilot is a name known to allsolopilot is a name known to allsolopilot is a name known to allsolopilot is a name known to allsolopilot is a name known to all
Could it be that you are taking too long in a command's execute() function?
Unread 02-03-2015, 12:53 PM
AKA: Isaac
We do occasionally and randomly get an error that says something about MotorSafetyHelper.h not updating fast enough on line 117, but there are two problems. One is that MotorSafetyHelper.h has no line 117, and we start running it. Any ideas?
Unread 02-03-2015, 01:47 PM
Dartmouth 2020
AKA: lopsided98
FRC #2084 (Robots by the C)
You are getting the MotorSafetyHelper error because you are not updating the motor outputs fast enough so the watchdog timer is expiring. If any execute method blocks for a long time, it will prevent all commands from running, therefore causing a watchdog timeout.
Unread 02-03-2015, 01:48 PM
AKA: Isaac
That's what we thought, but it doesn't happen every single time, which confused me. How would we fix that?
Unread 02-03-2015, 02:15 PM
That depends on what is making it take too long. We can guess at possible causes, but unless you show us your code we can't give confident help.
Post your code, as Kyle suggested in his first response.
Unread 02-03-2015, 02:29 PM
AKA: Isaac
I added the DriveBase subsystem, and the drive command to the post. Tell me what you think.
File Type: h DriveBase.h (652 Bytes, 7 views)
File Type: cpp TeleOpTankDrive.cpp (680 Bytes, 11 views)
File Type: h TeleOpTankDrive.h (274 Bytes, 6 views)
Last edited by King Nerd III : 02-03-2015 at 02:36 PM. Reason: added OI for oi->GetStickAxis
Unread 02-04-2015, 12:51 AM
kylelanman's Avatar
kylelanman kylelanman is offline
Programming Mentor
AKA: Kyle
FRC #2481 (Roboteers)
kylelanman is a name known to allkylelanman is a name known to allkylelanman is a name known to allkylelanman is a name known to allkylelanman is a name known to allkylelanman is a name known to all
 48void DriveBase::AutoDriveTurn(float speed, float angle){
 49         while(drive_gyro->GetAngle() >= angle){
 50                 fl_motor->Set(speed);
 51                 fr_motor->Set(speed);
 52                 bl_motor->Set(speed);
 53                 br_motor->Set(speed);
 54         }
 55 }
This function is going to cause you problems. This is called a "tight loop" and will consume all of your CPU power while blocking your main thread. Because there is no delay the CPU is going to execute the loop as fast as it possibly can. It will likely take the CPU to 100% and then start dropping control packets from the driver station. On top of that while you are in the loop none of your other commands or code in the main thread will be running.
The better way to do this that won't cause you problems is to use a command.
 32 class AutoDriveTurnCommand() {
 33 private:
 34     double mSpeed;
 35     double mAngle;
 36 public:
 37     AutoDriveTurnCommand(double speed, double angle) {
 38         mSpeed = speed;
 39         mAngle = angle;
 40     }
 41     void Initialize() {
 42         Robot::drivebase->DriveTank(speed, speed);
 43     }
 44     void Execute() {}
 45     bool IsFinished() {
 46         return Robot::drivebase->GetGyroAngle() < mAngle;
 47     }
 48     void End() {
 49         Robot::drivebase->DriveTank(0, 0);
 50     }
 51     void Interrupted() {
 52         End();
 53     }
 54 };
For this to work you will need to define a function in DriveBase called GetGyroAngle that returns the angle of the gyro.
"May the coms be with you"
Is this a "programming error" or a "programmer error"?
Unread 02-04-2015, 12:57 AM
AKA: Isaac
Originally Posted by kylelanman View Post
 54         }
 55 }
 33 private:
 34     double mSpeed;
 35     double mAngle;
 36 public:
 38         mSpeed = speed;
 39         mAngle = angle;
 40     }
 43     }
 47     }
 48     void End() {
 50     }
 52         End();
 53     }
 54 };
Thanks for the tip, but that couldn't be what's causing the error with not updating fast enough. That method isn't even called in the code yet, plus ita autonomous and we only get the error in teleop. Thanks for the tip, though! I'll probably use that!
Unread 12-10-2015, 03:22 PM
AKA: Isaac
I know this is an old thread, and I'm replying to myself, but yesterday we figured out the problem. In the Robot.cpp we were calling auto_command->End(); in the TeleOpInit Phase, but we had not given a specific command to auto_command, so when TeleOp was enabled it couldn't end the command and just died... At least that's how I believe we fixed it. Commenting out the auto_command->End() got rid of this problem, so we believe that's what it was.
Hope this helps!
Isaac
Isaac
Chief of Programming and Head of Autonomous Control
FRC Team 1410
