Go to Post If you think life is fair, you are sadly mistaken. - R.C. [more]
Unread 29-01-2015, 23:45
King Nerd III's Avatar
King Nerd III King Nerd III is offline
Chief Programmer/Head of Autonomous
AKA: Isaac
FRC #1410 (The Kraken)
King Nerd III is an unknown quantity at this point
roboRIO Command Based Problems
Has anyone else had problems with the roboRIO deleting Command Based code as soon as teleop is enabled? It's probably the worst problem we've had so far.
Unread 30-01-2015, 00:56
kylelanman's Avatar
kylelanman kylelanman is offline
Programming Mentor
AKA: Kyle
FRC #2481 (Roboteers)
kylelanman is a name known to allkylelanman is a name known to allkylelanman is a name known to allkylelanman is a name known to allkylelanman is a name known to allkylelanman is a name known to all
Re: roboRIO Command Based Problems
What do you mean by deleting it?
If the robot code light is turning off then most likely you are not initializing something properly and are getting null pointer exception and crashing your program on the RoboRio.
You can check the driver station log area for errors or you can do "Debug As" instead of "Run As" in eclipse. When your code crashes while debugging it will drop you in to the debugger with a stack trace showing you where the problem is.
If you are still having problems after that then post your code and we can take a look at it.
"May the coms be with you"
Is this a "programming error" or a "programmer error"?
Unread 30-01-2015, 00:59
AKA: Isaac
I mean it literally deletes it. The roboRIO says there is no code loaded, even if restarted.
Unread 30-01-2015, 01:08
kylelanman's Avatar
Programming Mentor
AKA: Kyle
What are the steps you are using to deploy your code to the RoboRio?
It is also possible that you are not initializing something properly in robotinit which runs before the robot is enabled.
It is entirely possible that the code is getting deleted as you have suggested but the Robot Code light is indicative of whether or not your program is running oppose to if your program actually exists on the RoboRio.
Unread 30-01-2015, 01:10
AKA: Isaac
We're going to reformat it again, that helped last time. Its annoying, though, as everytime we reformat it something else breaks.
Unread 30-01-2015, 08:59
Dartmouth 2020
AKA: lopsided98
FRC #2084 (Robots by the C)
Are you sure your code is not crashing? When your code crashes, the robot code light will turn off and a stack trace should be printed to the log window in the DS. I doubt it is actually being deleted.
Unread 03-02-2015, 11:33
AKA: Isaac
We fixed the problem by reformatting it 20 or so times. We also had a problem with a roboRIO where some kid turned it off WHILE IT WAS FORMATTING. Of course we fixed it, but it took a bunch of formatting.
Long story short the lesson here is when in doubt reformat until it works!
Unread 03-02-2015, 11:49
I doubt that is good advice. Unless there is something physically wrong with the system, reimaging a roboRIO a bunch of times can't do anything that reimaging it once will do. The class of problems that can be solved with a single reimage step is very small, and they are very rare.
Instead of going for the reimaging/reformatting voodoo, you should troubleshoot your original problem using the tools suggested here by the people trying to help you.
Unread 03-02-2015, 11:52
AKA: Isaac
It's usually all that works for us. The troubleshooting will help with minor things, but when the robot is turned off mid format? Nothing else would help. Heck, the troubleshooting tools wouldn't even detect the roboRIO.
Unread 03-02-2015, 12:27
solopilot solopilot is online now
FRC #0293
solopilot is a name known to allsolopilot is a name known to allsolopilot is a name known to allsolopilot is a name known to allsolopilot is a name known to allsolopilot is a name known to all
Could it be that you are taking too long in a command's execute() function?
Unread 03-02-2015, 12:53
AKA: Isaac
We do occasionally and randomly get an error that says something about MotorSafetyHelper.h not updating fast enough on line 117, but there are two problems. One is that MotorSafetyHelper.h has no line 117, and we start running it. Any ideas?
Unread 03-02-2015, 13:47
Dartmouth 2020
AKA: lopsided98
You are getting the MotorSafetyHelper error because you are not updating the motor outputs fast enough so the watchdog timer is expiring. If any execute method blocks for a long time, it will prevent all commands from running, therefore causing a watchdog timeout.
Unread 03-02-2015, 13:48
AKA: Isaac
That's what we thought, but it doesn't happen every single time, which confused me. How would we fix that?
Unread 03-02-2015, 14:15
That depends on what is making it take too long. We can guess at possible causes, but unless you show us your code we can't give confident help.
Post your code, as Kyle suggested in his first response.
Unread 03-02-2015, 14:29
AKA: Isaac
I added the DriveBase subsystem, and the drive command to the post. Tell me what you think.
File Type: h DriveBase.h (652 Bytes, 8 views)
File Type: cpp TeleOpTankDrive.cpp (680 Bytes, 12 views)
File Type: h TeleOpTankDrive.h (274 Bytes, 7 views)
Last edited by King Nerd III : 03-02-2015 at 14:36. Reason: added OI for oi->GetStickAxis
