Go to Post For those who don't have snow in the forecast - i.e., not New England - just send me your shipping address and I'll FedEx some snow to you right away. We have extra. :p - DonRotolo [more]
Thread Tools Rating: Thread Rating: 7 votes, 5.00 average. Display Modes
  #31   Spotlight this post!
Unread 03-02-2015, 14:46
juchong's Avatar
juchong juchong is offline
Electrical Engineer
AKA: Juan Chong
FRC #2655 (Flying Platypi)
juchong is a jewel in the roughjuchong is a jewel in the roughjuchong is a jewel in the rough
Re: Anderson PowerPole for CAN bus?
I agree that using Andersons for CAN lines is definitely overkill. A good, cheap alternative we found is to use JST SM connectors found over at Adafruit. Solid connection, easy to attach (no special crimper required), polarized, and CHEAP!
http://www.adafruit.com/products/319
http://www.adafruit.com/products/318
No need to use a jackhammer here, folks! Not everyone is made of money!
Teams I've worked with:My Website: http://www.juanjchong.com/
What I do: Analog Devices iSensor Product Engineer
  #32   Spotlight this post!
Unread 03-02-2015, 14:52
notmattlythgoe's Avatar
Flywheel Police
AKA: Matthew Lythgoe
FRC #2363 (Triple Helix)
I've been trying to find something like this without the wires already built in. Something like these without the wires.
  #33   Spotlight this post!
Unread 03-02-2015, 15:23
pntbll1313's Avatar
pntbll1313 pntbll1313 is offline
2052 Coach, Build/Electrical Mentor
AKA: Pete
FRC #2052 (KnightKrawler)
pntbll1313 has much to be proud ofpntbll1313 has much to be proud ofpntbll1313 has much to be proud ofpntbll1313 has much to be proud ofpntbll1313 has much to be proud ofpntbll1313 has much to be proud ofpntbll1313 has much to be proud ofpntbll1313 has much to be proud ofpntbll1313 has much to be proud ofpntbll1313 has much to be proud of
The description on Amazon isn't the greatest but you may be looking for This and This. You'd have to buy the Contacts Separately.
2016 (mentor/drive-coach)
Quarter-Finalist-Einstein, Winner-Carson Division Champs, Winner-10K Lakes, Chairman's Award-10K Lakes, Finalists-Lake Superior,
Winner-MSHSL Robotics Competition
2015 (mentor/drive-coach)
Finalists-10K Lakes, Finalists-Lake Superior, Finalist-MSHL Robotics Competition, Quarter-Finalist-Galileo Division Champs
2014 (mentor/drive-coach)
Winner-10K Lakes, Winner-Lake Superior Winner-MSHSL Robotics Competition, Quarter-Finalist-Galileo Division Champs
2013 (mentor/drive-coach)
Winner-10K Lakes, Winner-Lake Superior, Winner-MSHSL Robotics Competition, Quarter-Finalist-Newton Division Champs
2012 (mentor/drive-coach)
Finalists-Lake Superior, Semi-Finalist-MSHSL State Championship, Semi-Finalists at 10,000 Lakes
2008-2011 (college mentor)
2007 (driver)
Quarter Finalist-Milwaukee
  #34   Spotlight this post!
Unread 03-02-2015, 15:30
Flywheel Police
You sir, you are the man.
  #35   Spotlight this post!
Unread 04-02-2015, 09:57
philso philso is offline
FRC #2587
Originally Posted by wireties View Post
The best connectors have a profile similar to the diameter of the wire. The reflections occur at impedance mismatches and the impedance of the connector is largely a function of the geometry. In an ideal world the wire and all the connectors would have the same impedance at 1Mhz and the terminations at each end would be 2X that impedance, nominally 50-60 ohms for CAN. Note that this is impedance, not purely resistance.
We have used PWM connectors and Molex connectors (for 20AWG wire) with zero issues running 9 Talons. Powerpole pins are overkill for the current and are larger than 20AWG wire - I would shy away from using them.
Good luck!
+1
We are looking at using the locking PWM connectors from Hansen Hobbies. They use different contact pins than the "normal" PWM connectors they sell but the same crimper can be used. Like the PWM connectors commonly used in FRC, they have a physical configuration that is more similar to the physical configuration than most of the small connectors I have found (and many of those suggested in this thread).
The 30A and 45A Anderson connectors can work for the CAN Bus connections but will probably present a larger disruption to the characteristic impedance than the PWM connectors. They are also meant for minimum wire sizes of 16AWG and 14AWG, respectively, so extra precautions will have to be taken to ensure a good electrical and mechanical connection is made. It is also likely that people pull on the wires to un-mate the connectors. While the 16AWG to 10AWG wire that is normally used might survive this type of abuse, the 22AWG CAN Bus wires that are part of the motor controllers will be more likely to be damaged.
I have used my industry contacts to find a small connector for the CAN Bus connections but have yet to find a better solution than the parts from Hansen. The parts I was able to find either required the purchase of a special tool from the connector manufacturer (typically $100's) or were rated for an unacceptably low number of mating cycles (i.e. 25 vs 10,000 for the 45 A Anderson and others). It would be best to check the tooling required and the mating cycle rating before committing to a connector type.
  #36   Spotlight this post!
Unread 04-02-2015, 10:05
The characteristic impedance of the CAN cable is spec'd at 120 ohms, not 55.
  #37   Spotlight this post!
Unread 04-02-2015, 12:29
mikeh2338 mikeh2338 is offline
FRC #2338 (Gear It Forward)
mikeh2338 is an unknown quantity at this point
We looked at several connector solutions to make potential Talon change outs easy during competition. A lot of the polarized solutions we considered had costs of ~$1 per connector and used the small crimp pins that the kids sometime struggle with. Then we discovered the WAGO 222-412 2-terminal block. We bought 50 of these for about $0.35 each at Newark (link). The WAGO is small, takes a wide range of wire gauges (28-12 AWG), and has nifty little levers for thumb or WAGO tool operation.
We initially used several of the small terminal blocks that come with the annual KOP to wire up the prototype electrical subsystem and had trouble with an unreliable CAN bus. All our CAN communications issues disappeared after swapping in the little WAGOs.
  #38   Spotlight this post!
Unread 08-02-2015, 18:38
wireties's Avatar
wireties wireties is online now
Principal Engineer
AKA: Keith Buchanan
Sorry, the 2X should be 1/2X making the termination similar to the cable impedance - thanks for the correction.
  #39   Spotlight this post!
Unread 08-02-2015, 18:45
kyle_hamblett's Avatar
kyle_hamblett kyle_hamblett is offline
Hamby
FRC #1073 (The Force Team)
kyle_hamblett will become famous soon enoughkyle_hamblett will become famous soon enough
We are using the same connectors that would be on the Talon SR or Victor so if we ever decide to utilize PWM over CAN, we can do so without having to change the controller wiring.
