Go to Post We were asked to help change a culture. If the solution was simple FIRST would have given more specific guidelines on how to do this. It is our job as teams to find unique and creative ways to help fulfill the request from FIRST. - tim-tim [more]
Unread 03-02-2015, 20:31
team-4480's Avatar
team-4480 team-4480 is offline
Debug? What's that?
FRC #4480
team-4480 will become famous soon enoughteam-4480 will become famous soon enough
Python: TypeError: set_disabled() takes 1 positional argument?
Hi! We are running into a problem with our code when we try to run the Pyfrc Sim. I am testing using some switches with DigitalInputs and I was checking for errors since I am out of reach of the robot. Code: http://pastebin.com/Es4z97GK. I get this error when running the sim.
Traceback (most recent call last):
  File "robot.py", line 84, in <module>
    wpilib.run(MyRobot)
  File "/Library/Frameworks/Python.framework/Versions/3.4/lib/python3.4/site-packages/wpilib/_impl/main.py", line 100, in run
    retval = options.cmdobj.run(options, robot_class, **kwargs)
  File "/Library/Frameworks/Python.framework/Versions/3.4/lib/python3.4/site-packages/pyfrc/mains/cli_sim.py", line 46, in run
    ui = sim.SimUI(sim_manager, fake_time, field_size, px_per_ft)
  File "/Library/Frameworks/Python.framework/Versions/3.4/lib/python3.4/site-packages/pyfrc/sim/ui.py", line 59, in __init__
    self.timer_fired()
  File "/Library/Frameworks/Python.framework/Versions/3.4/lib/python3.4/site-packages/pyfrc/sim/ui.py", line 329, in timer_fired
    self.update_widgets()
  File "/Library/Frameworks/Python.framework/Versions/3.4/lib/python3.4/site-packages/pyfrc/sim/ui.py", line 361, in update_widgets
    dio.set_disabled(False)
TypeError: set_disabled() takes 1 positional argument but 2 were given
Any help will be greatly appreciated!!
Unread 03-02-2015, 21:33
TimTheGreat's Avatar
TimTheGreat TimTheGreat is offline
ArchdukeTim
FRC #1418 (Vae Victis)
TimTheGreat has a spectacular aura aboutTimTheGreat has a spectacular aura aboutTimTheGreat has a spectacular aura about
Re: Python: TypeError: set_disabled() takes 1 positional argument?
Update pyfrc
There are two ways of constructing a software design: One way is to make it so simple that there are obviously no deficiencies, and the other way is to make it so complicated that there are no obvious deficiencies. The first method is far more difficult.
2012 - Gracious Professionalism - Greater DC
2014 - Regional Finalist - Virginia | Industrial Design - Virginia | Regional Finalist - Greater DC
2015 - Innovation in Control - Greater DC
2016 - District Event Winner - VAHAY | Innovation in Control - VAHAY | District Event Winner - MDBET | Industrial Design - MDBET | District Champion - CHCMP | Innovation in Control - CHCMP
Unread 03-02-2015, 22:03
team-4480's Avatar
Debug? What's that?
FRC #4480
Originally Posted by TimTheGreat View Post
Update pyfrc
Oh....that fixed it.....thanks! It really should be a "HumanError: Brain not found"!
Unread 03-02-2015, 22:11
ArchdukeTim
Well, until Dustin (virtualD) puts "Update pyfrc" into the error message there really isn't a way to know.
Unread 03-02-2015, 23:14
virtuald's Avatar
virtuald virtuald is offline
RobotPy Guy
AKA: Dustin Spicuzza
Well, if I knew there was an error message, then I wouldn't have had the bug to begin with!
However, as Tim points out, if you run into a weird error, it's always best to make sure that you have the latest version -- especially this year, with so many new things for the new control system.
