Go to Post FIRST robotics: Not just for nerds. - Koko Ed [more]
Unread 30-01-2015, 21:18
Herbblood's Avatar
Herbblood Herbblood is offline
Knowledgeable
AKA: Ally
FRC #3044 (OxBE4)
Herbblood is an unknown quantity at this point
Custom Dashboard
Hi!
I've been working on a custom dashboard for the 2015 driver station. However I've run into some difficulties when trying to get the dashboard to run with the driver station. I've tried doing what I suggested for the smart dashboard (as shown here ) but it doesn't work. Any help please?
Off to WPI!
Go OxBE4
Unread 03-02-2015, 18:52
Herbblood's Avatar
Knowledgeable
AKA: Ally
FRC #3044 (OxBE4)
Re: Custom Dashboard
If anyone has any insight it would be nice
Off to WPI!
Go OxBE4
Unread 03-02-2015, 19:24
Dartmouth 2020
AKA: lopsided98
FRC #2084 (Robots by the C)
Is your custom dashboard written in Java?
If so, are you able to get the SmartDashboard to load per those instructions, just to make sure java is working right?
Unread 03-02-2015, 19:33
Herbblood's Avatar
Knowledgeable
AKA: Ally
FRC #3044 (OxBE4)
My custom dashboard is written in java
I'm unsure how you would implement it in smartdashboard, since I coded it with jframes.
Off to WPI!
Go OxBE4
Unread 03-02-2015, 19:55
Dartmouth 2020
AKA: lopsided98
I just wanted you to try getting the SmartDashboard to work to make sure the DS is able to load a Java program. I have heard of cases where Java had to be specified as an absolute path.
If you can get the SmartDashboard to work then there is probably something wrong with your custom dashboard.
Unread 03-02-2015, 20:44
nickmcski nickmcski is offline
AKA: Nicholas McCurry
FRC #1482 (Grandin Ghosts)
nickmcski has a spectacular aura aboutnickmcski has a spectacular aura aboutnickmcski has a spectacular aura about
Talking Re: Custom Dashboard
The command it runs is basically same command it would run in command prompt. I would recommend running the command in command so you will be able to see if there is an error. If everything works there then copy the command you ran into the driver station config file.
